ajvx01
- Dec 13, 2010
- 911
- 6
- 18
- Location
- North east Adelaide
- 308 vc
Has anyone ever put BMW seats into their first gen commodore ? Thinking some e36 would look good when I do the re trim .
Doing this with electronic seats make it harder. I'm assuming you mean full Vader seats and not the is seats?
The easiest way which unsure of E36 but E30 is still base mount four bolt rails. Welding up a a rectangular bracket that bolts into the seat and you original rail is always the easiest but unless you have height adjust on your original rail you won't on the new seat.
You'll only have forwards/backwards and tilt. The other way is to cut the mounting tabs flush and weld adapter plates on the bottom of the rail to your existing holes. This will make the seat sit quite high as most BMW seats I've seen have an offset height where the mount to the floor. Think tunnels much closer to seat then outers.
