Body filler rejuvenation
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
I need some advice from the panelbeater, painters or scientists on this forum.
I have a large tin of good quality plastic filler which is barely used but is going dry in the can, even with the lid sealed firmly. Does anybody know what can be added to the filler to restore its correct texture for mixing ie soften and restore the moisture level prior to adding the hardener?
Noeleter
VEII Equipe Sportwagon
The resin even if stored under ideal conditions will deteriorate after about 6 months. It is false economy to try and use it.
Calaber
Thanks mate. I used it today to fill some timber cracks and it was fine but very stiff to mix and spread. Might as well chuck it and get a new can when I need it.
1985VK
Australia
VK SL
If it's headed for the bin you could try a hint of mineral turps mixed into the filler and see if it saves it (for non critical jobs).
WazzaVN
Wazza VN
VZ 6ltr ute, VP Calais and HJ Prem
Mix it up with a few drabs of paint thinner usually gets old bog to spread better. If you're only using it for a few jobs it's worth a try if you're going nuts with it it's gonna be a pain in the arse and you might just wanna get some new stuff haha.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
They all have a shelf life....
Just buy smaller quantities when required.
ephect
Donating Member
VS Acclaim V6
If it's only timber your fixing, get timbermate, good stuff, and if it goes dry add a bit of warm water to bring it back to life.
Sorry I can't help reviving your current tin
losh1971
North Tas
VE Series I SS Ute
You could try some acetone but like mentioned it's probably not economical to revive it. Sounds like it must be pretty old anyway. I have used bog that was 7-8 years old in a tin that was half full and it was still ok. Only issue was once you added the hardener it went off really quick so you got about 2-3 mins, if that to apply it before it went to jelly.
