Body rubber weather strip.
philbo 53
71
Stawell Vic
2016 Calais
Hi, just wondering how to replace the rubber front RH door opening body seal on Holden 2016 Calais.
NJD-1992
VF-S2 SV6 Commodore
It just pulls off, then you just press the new one on, making sure to line up the corners
There will be a channel on the seal that goes over a metal ridge that flows around the door.
Hard to describe but very easy to see when you pull the seal off
BlackVXGTS
Melbourne, SE
Your reply is about the seal on the door. Unless I am mistaken, the OP was referring to the seal which is on the body. Removing/replacing that one is a little more complicated.
NJD-1992
VF-S2 SV6 Commodore
That’s the one I was referring to?
Have removed mine and reinstalled mine and only took a few minutes
Edit: should have clarified in my initial post, in that I meant the door cutout in the chassis
philbo 53
71
Stawell Vic
2016 Calais
Thank you so much, I appreciate your help.
