bonnet cable works when it wants to!
mwhit43
Vs excuetive
ok, so i pulled the bonnet release and the bonnet clicked and it didn't open its been doing it for a while now, the bonnet cable just works when it wants to, is there a soloution? would the cable need to be replaced?
bogan_vk
australia
commodore
either replace the cable or hitting the bonnet in the d/s corner as youve got the lever pulled usually opens it.
bogan_vk
australia
commodore
just disconnect it from the handle you pull disconnect it from the radiator support/latch and pull it through the firewall first taking note where it is routed so when you feed another through so you know where to run it, but now i think about it you should be able to just loosen the screw clamping the cable to the radiator support and pull the cable to tension it a bit and retighten, id try that before you waste money on a new cable .
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
THERE IS A SMALL ROOM FOR AJUSTMENT) if it aint broken)
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
Try some grease on the lock pin. The old stuff dries out and the bonnet wont pop open.
This extra friction doesn't help the cable!
Hangman
Aspiring Sociopath
Newcastle, home of Toranafest
WK Land Yacht
If it's at the stage where you have to push on the bonnet to open it, it will break sooner or later. I'm on my second cable in the VP, but I replaced it with a freebie that has the same problem. Might buy a new one when this one goes.
Good point about greasing it too.
BerlinaBoy
Brisbane (Southside)
V6 VR Berlina - Stock standard
Yeah, my VR gets stuck when I haven't greased it in 6 mths or so - been doing it for a few years. Run around and do your door hinges and bonnet catch etc with some white grease.
