Bonnet gas struts
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by mr calais 5.0, Jun 21, 2011.
  1. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    I'm looking into fitting the gas struts to the bonnet and removing the bar that holds it up.. So my question is will struts from a vr/vs or even newer work and how far from the hinges do I fit them on? Any pics would help as well if you got them..
  2. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    i bought a reco'd set off ebay and they do work but there stiff as hell and need a helping hand to spring up. youll also need the mounting knobs that bolt to the top of the guards and the one that screws into the bonnet. its a 10 min job. think the vr vs ones are the same as vp. just go to the wreckers and pocket the 4 bolt knobs and just remember where they go....
    HOLDEN VP-VR-VS BONNET gas struts - new pair !!! | eBay
  3. mr calais 5.0
    victoria
    vy s 2003
    Thanks for that.. Will stop at the wreckers tomorrow after work and before I get the kids from school..
  4. Shortstuff
    Shortstuff Random
    2016 Golf GTI PP
  5. mr calais 5.0
    victoria
    vy s 2003
    Was looking at the how to and it's a huge help.. Thanks for that...
  6. mr calais 5.0
    victoria
    vy s 2003
    Was looking at the bolts on the guards and then looked at the bonnet and it has the holes on the side.. Spoze I don't have to drill holes so I'm half way there
  7. hi_ryder
    didnt realize that cause when i did my vn it changed it to a vp bonnet, the other one was stuffed and i was doing a respray anyway... that nut on the wire is pretty clever nice one....
  8. Morton
    Morton For external use only
    Fairstar the Funship
    Also make sure you get some flat-top studs for the quarter panel. The standard nuts won't give the struts enough clearance when the bonnet shuts.
    They have studs on them, and you do the nut up from underneath. They're the white squares in this picture:
