Bonnet hinge sag
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VR38, Aug 7, 2011.
  1. VR38
    VR38 Well-Known Member
    VB SL/E
    I have seen second gen commodore hinges sag to the point of cracking the windscreen when the bonnet is lifted, what is the preventative maintenance and rectification for this?
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Lubricate the hinges. They get dry and the pin pops, causing the corner of the bonnet to hit the windscreen.
  3. VR38
    VB SL/E
    I do lube them and they are operating smooth but the bonnet sits a few millimetres low at the back which I thought was sag, I maybe able to adjust it up but don't want to band aid the problem, is new hinges the only fix?
    Is it the pivot points?
    What to look for in used hinges?
  4. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    I was also wondering about this. The bonnet on my VS sits low at the back and people keep mentioning it to me but I don't know how to fix it.
  5. CAPRILICIOUS WL
    CAPRILICIOUS WL New Member
    WL CAPRICE
    I'd like to realign mine as its got a big gab between the guard on the left near the lights and a very small gap on the right again near the lights.
    But don't know how to go about it.
  6. VR38
    VB SL/E
    Sounds like you are going to crack the screen soon, how is the height alignment between the guard and bonnet at the windscreen?
    maybe a new set of hinges for you...
  7. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Whatever you do, be carful if you try to remove the bonnet and get to the hinge. The hinge will fly open and slap onto the front window...and crack it. Just to be safe slap a few bed pillows on the windscreen before you start just incase.
  8. VR38
    VB SL/E
    How do they do that?
    They have no spring...
  9. VrWagz1
    wollongong
    hmmmm, got me there....maybe im thinking of another make car:s
  10. CAPRILICIOUS WL
    WL CAPRICE
    The height is fine it's just a gap on one side next to the headlights and the other side has a tiny gap is almost gonna touch.
  11. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    You can adjust the mud gaurds a little to give the bonnet a more even gap on each side - I've done it several times to the VN's when re fitting bonnets.
    As for the bonnet sagging at the rear next to the windscreen - the hinges are bent. Fit new hinges to make the bonnet sit level again.
  12. Cheap6
    Cheap6 New Member
    VP Exec
    While new hinges are best and easiest it may be worth playing with the old ones.
    If you place something like a block of wood inside the parallelogram described by the hinge that will stop it from closing and you will be able to bend the part that the bonnet bolts to relative to that. Be careful closing the bonnet after any adjustment of course.
    I'd probably just go ahead and fit the new hinges though.
  13. VR38
    VB SL/E
    There does not appear to be any bent parts in the hinge but then closed I can lift the left hand side next to the window, can actually rattle it up and down.
  14. Cheap6
    Cheap6 New Member
    VP Exec
    So, unless the bolts are loose, the pins are worn and you need (a) new hinge(s).
