Boot & Parkers?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by rippen50, Nov 17, 2008.
  1. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    How to install boot and parker Lights any help would be appreciated.. Cheers =]
  2. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    well i own a vn, not sure differences but hope itl giv u a vague idea.
    Boot light; Simply get a flathead screwdriver and pop the cover off and take the globe out and replace with one of ur choice.
    Parkers: Behind the headlight theres a screw cap, unscrew and theres a small light insert area with 2 wires running into it, its about 10mm wide circular and pulls out, thats your parker, simply pull off the current globe and put ur other one on.
    gdluk :)
  3. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    so im guessing the headlights are the same as the rear lights... ill have a look and check it out cheers for the reply mate
  4. Lumps of cheese
    Lumps of cheese welcome to the machine
    Warrnambool
    83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
    The boot has a plastic cover where the catch is. Just use a screwdriver to gently lever out the plastic catches to free it, then you just unscrew the plastic screws holding the carpet to get you to the light.
    The front ones are a pain because of room. They have a cover that screws off the back of the light but good luck getting to it, need someone with small hands!
  5. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    boot lights are in... way easy... pop the light out take out the bulb replace!... took no longer than 2mins a light... parkers getn put in soon cheers
