This is for a VP Commodore man, none of that is ever gonna happen, it is physically not capable. Why a mechanic would be playing with injector flow settings during a routine service too is beyond me.
Are you talking about reprogramming injector IDs (which don't exist on this car) or actually changing flow (which also doesn't exist that way on this car)? Because the whole idea of flow testing is so that you don't have to adjust flow like that.
Well then why send them off then there nothing they can do to adjust the injectors rate they can only clean them if they any good to start with, if they clean and working then only thing that will stop there performance is fuel pressure.
VN series 1, 8-88 to 10-90 uses injector number 0280-150-901 which flows 146.3 GPM @ 3 BAR. Resistance 14.5 ?.
VN series 2, 11-90 to 10-91 uses injector number 028-0150-960 which flows 150.5 GPM @ 3 BAR. Resistance 14.5 ?.
These injectors are also fitted in the
VG UTE 11-90 to 10-91, VP COMMODORE 11-91 to 07-93 and the VR COMMODORE 06-93 to 04-95.
The VN - VR injectors are what is classed as an EV-1 injector pintle type which are open to problems when used at an incorrect fuel pressure, hosing is a problem if pressure is too low or too high and the pattern can also be forced too wide for the target area if pressure is too high.
