Brain dead.
Discussion in 'Car Audio' started by Ryder15, Feb 24, 2010.
  1. Ryder15
    Ryder15 New Member
    vs commadore Ute 1999
    hey guys, had a brain fart
    just a quick one
    I installed my CD playing into my Vs 1999 v6 yesterday
    when ever i start the car the CD play has reset itself
    im pretty sure i have either gotton the earthing wire and the memory wire Crossed over
    Just wondering witch colour is witch
    Matty.
  2. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    I'm sure that if you plugged the earth to a positive supply it wouldn't turn on/blow up.
  3. Fun_Bucket
    Fun_Bucket New Member
    Cairns White Rock
    Cruze II sri
  4. Lady Calais
    Lady Calais New Member
    Skye VIC
    VX II Calais
    the ignition power from the car wiring harness is connected to a consent 12 v wire on the head unit and then then the constant 12 v from the wiring harness is plugged into the accessory wire on the head unit.
  5. Fun_Bucket
    Cairns White Rock
    Cruze II sri
    your not using a wiring harness adapter are you?
  6. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    had the same problem i think mine was deleting all of my saved raido stations and stuff.
    there 2 wires 12volts constant witch would go with a memory wire or somthing like that mine was yellow and the outher was 12volts switched with is just you power wire usely the red one
  7. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    The link that was posted has all the info you need.
