Brake Fluid... Which DOT?
VT Dave
41
Supercharged 98 VT S pac
Hey, just a quick question. Which DOT brake fluid do you use in your VT. The only code i could find was something like HN 1796. What does that translate into in english. DOT 3 or DOT 4?
VT Dave
41
Cheers guys... Talk about prompt service, get an answer in 3 minutes or less.
Vzproject
37
Lalor park
Vz Acclaim sedan 05
that will be fine.
Cool thanks mate I changed my master cylinder because my one was leaking from the switch on the bottom the new one isn't leaking but I've put a litre of fluid through and still no peddle and still air in the system do I just need to use more fluid and keep bleeding till no air and I have peddle or is there something else I should do?
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Did you bench bleed the M/C before installing it?
Vzproject
37
Lalor park
Vz Acclaim sedan 05
Nah I didn't is that the screw on the side of the mc? Can I do it while it's on the car or do I just have to take it off?
stick3
newcastle nsw
vz sedan vs ute gsx1400
you can do it in the car need some one to push the pedal and hold while you crack the front line first to you see fluid than tighten do the same with rear line have a rag and water handy
you might have to bleed the brakes again if you got air in the abs
