Brett_jjj
- Oct 16, 2009
- 6,805
- 108
- 48
- Location
- Tamworth NSW
- vs commodore
All you need to do to flush the brake system is to get someone to hold the brake pedal in, get someone else to keep the master cylinder topped up with fresh brake fluid, dont let the fluid level fall below half way in the M/C , then crack the brake bleed nipples, one at a time, starting at the one furtherest away from the master cylinder,(usually rear left wheel), and get the person to pump the brake pedal a few times and then hold it in fully whilst you crack open the bleed nipple half a turn. Make sure the brake pedal is always held in full whilst the nipple is cracked open, otherwise it will suck air back into the brake system.. Keep doing the above, pumping up the brake pedal, holding it in, and opening the bleeder half a turn to let out the old fluid, keep repeating this until the clean new fluid comes through, then move onto the next wheel until theyre all done. Its pretty easy.
