Brake Fluid
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Haydz, Jan 30, 2009.
  1. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    hey guys.
    going to be replacing my brake fluid in my vr.
    just wondering whats the best sort for my car. and commodores in general
    thanks again :dance:
  2. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    I think i used dot 3 last time, but the higher the dot the better.
  3. greenacc
    greenacc Searching for the billion
    VE Berlina
    very timely question Haydz .. I'm doing mine tonight too.
    I reckon all the regular dot 4's are all about the same. I am using Valvoline 'Performance Dot 4', it has a high boiling point. i reckon the PBR dot 4 is ok too. I assume VR's use DOT 4 ?
  4. gslrallysport
    gslrallysport Active Member
    VZ AWD One Tonner
    The fluid we use and recommend is the TRW GP600 brake fluid:
    TRW GP600 Dot 4 Racing Brake Fluid
    Dry - Min 310
    Wet - Min 204
    That's about the best out there short of Castrol SRF, or GS610. But significantly cheaper than either of them at $59 for a 1L bottle.
    For comparison, some other popular brands:
    Motul Dot 5.1
    270 dry
    185 wet
    Castrol Response Super Dot 4
    286 dry
    184 wet
    Valvoline Performance Dot 4
    270 dry
    Your regular Dot 4's are a fair bit lower than that.
  5. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    The legal minimum boil temperatures for Dot 4 is dry 230 and wet 155 - that's about what your el-cheapo $6 per 500ml brake fluid rates at.
    The reality is that most people don't drive racing cars and the el-cheapo brand will perform as well as expensive name brands under normal driving conditions.
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    What ever you do, keep track of what you use as you can't mix DOT3 and DOT4.
    I'm pretty sure the VR's were DOT3 from factory as the DOT4 wasn't around in '93. But it is only a guess.
  7. VrWagz1
    wollongong
    Well, im replacing all my fluid with dot 4 tommorow, due to track day:p
  8. Torquative
    Torquative Sports Economy
    VE SV6 3.6L SIDI 6sp
    me too ... just its a week later :whistling
