Brake lights and cruise control don't work
Discussion in 'VY Holden Commodore (2002 - 2004)' started by savage1987, Aug 21, 2008.
  1. savage1987
    savage1987 Donating Member
    VY Tonner V6: Cruise won't activate, it enables but won't activate. Brake lights don't work, globes are fine. Any common causes?? I checked a couple of fuses, the obvious ones are OK.
    Sam
  2. KiWi1
    KiWi1 11.00@126 Miss dat ****
    HIGGINS RACE DEVELOPMENTS
    Dead 11sec VX SS, Defected VP Ute
    Do you have a tow bar? disconnect it, and re check ALL fuses. Some problems electrically, have occured, from the tow bar plug being connected. Usually, its the tail lights, and dash lights not working (same fuse link)
    Simon
  3. savage1987
    Really?? hmm. Yes there's a towbar but what do you want me to disconnect?? Trailer's off and the plug's out, if that's what you mean..
    Dash lights work fine, so do the taillights, only brake lights and cruise have failed.
    Sam
  4. KiWi1
    re check all your fuses, but yeah my fuse blew countless times, loosing tail lights, and dash lights. ended up being the trailer plug. I disconnected the trailer plug to the loom plug, and it stopped.
    Id check all fuses first bro. look on your fuse panel label, and find out which fuse matches your blown items.
  5. CANYONERO
    CANYONERO Likes Cheese...
    Country SA
    V8 6spd wif MOMO leavaa.
    has it had a LED brake light conversion?
  6. Flat_White
    Flat_White Banned
    Rolls Royce "Fantom"
    after you press the cruise button you need to twist the switch up or down to enable cruise control (i think)
  7. savage1987
    No, it's on the cards though as these ****ty taillights keep dropping globes.
    Sure do, that's the bit that isn't working. Had the car for years, know how cruise control works :) but thanks anyway mate.
    I've checked the cruise control and brake light fuses under the column there, nothing. I'll go through every fuse tomorrow.
    Sam
  8. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    What about the cruise cancel switch and brake light swithch on the pedal. It sorta sounds to me like the plug has come off that swithch.
  9. savage1987
    yes that's what I was thinking also.... brake pedal switch would make sense. How do I get to it?
    Sam
  10. savage1987
    Just to clear this up, it was the blown brake light globes. Apparently if BOTH globes are blown, cruise control will still ENABLE, but will not ACTIVATE. Lesson learned :)
    Sam
  11. MUT4NT
    MUT4NT RatRod Gem Wagon?
    PERTH
    WH international// Gemini Wagon
    i had the brake light problem on my VP man
    i just bought new sockets which then makes it work a treat :)
