brake lights controll tcc lock and unlock?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Mar 7, 2012.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hi ive herd the brake light switch and cruise control switch (on brake pedal) controls if your auto converter locks up or not
    is this true? like if mine was faulty could it cause the tcc to not lock? i got cruis control but also have the other brake switch installed aswell as the cruise controll one, should i only have the one?\
    just trying to see if this is causeing my tcc problems
    also brake lights work fine as they should lol
    cheers
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    No, the brake light switch has nothing to do with the TCC. All it does is make the brake lights work and deactivate the cruise.
    You probably have a faulty TCC lockup solenoid. Common problem.
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I don't doubt that you are correct NAAF, but many yank sites say the one test of unlocking the TCC on the 4L60E is to touch the brakes. It seems to make sense that it would disengage it because if the brakes locked the rear wheels there would still be be a solid connection from the rear wheel (stationary) and the engine which is rotating at speed with the TCC engaged.
  4. wamboin23
    wamboin23 Donating Member w/ Boost
    Wamboin, NSW
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    there is no brake light connection to the PCM, so brakes shouldn't have any effect to TCC operation.
  5. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    The reason it says to do that is change the vehicle's speed, this unlocks the TCC, not the actual application of the brakes.
  6. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Re brake switch - looks like it only applies to older models of 4L60/E as I found this on a yank forum:
    Well, I checked the TCC solenoid and it wasn't cracked, so I am going to look at the brake switches tomorrow. My Haynes 99-2006 manual shows a brake wire going to the computer.
    My friend who owns a trans shop in another state said the brake switch is a thing of the past on the 05, but we will see.
    Thanks for the tip.
    So that seems to indicate it was deleted somewhere along the line.
  7. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    There you go, but a lot of US cars have weird set ups compared to Aus. Or is it the other way around?...
  8. jas98
    jas98 Active Member
    maryborough QLD
    thanks guys, i didnt think it was connected with the tcc but as hako said allot of the US forums say this when they have trouble with the tcc
    anyway cheers for all this
