Brake line tube nut size
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by FCV8, Feb 19, 2018.
  1. FCV8
    FCV8 New Member
    Hi guys. Im fitting vn discs to a fc holden. Ive bent up the 3/16 steel lines and trying to find out the size of the front and back tube nuts that screw into the flex lines?
    FCV8
  2. VPRob
    VPRob Active Member
    nowra, NSW
    VP executive sedan V6
    wow. Anything will be an improvement on the standard FC brakes. I don't know the size you are after but the other consideration is the flair on the end of the lines. It changed between the VN and VP. Obviously you have made up some lines so don't know what you will have but it will affect how easily it seals. Are you using the VN V8 rotors on the front and what MC and booster are you using?
  3. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Take your caliper to a brake place and buy the nuts that suit and do the same for the MC if you need those ends as well.
  4. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    flare adapters I use for vn on use m10 x 1 on small flare nuts at master cylinder and m12 x 1 on the larger threaded ones
