Brake Pad Squeeking
Discussion in 'General' started by r_i_d_a_h, Sep 7, 2007.
  1. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    i have this squeeking noise coming from the rear driver side wheel and the squeeking comes in intervals and the faster i go the faster the squeaks although when i press the brakes it goes away.
    Anyway i took the caliper off and took a look at the pads, i found that the outter brake pad surface wasnt all smooth compared to the inner pad, there was an area on the pad where it felt really rough, i've cirlced the rough area in yellow in the pic (the picture is just an example).
    is this the culprit for my squeeking problem??
  2. jules
    jules we like the bun
    pimpin
    check that there is a steel shim behind the pad. last time i forgot to replace the backing shims they squealed like a pig :)
    from memory the reason was that the shims didn't come with the replacement pads, i had to transfer them from the old ones.
  3. r_i_d_a_h
    is that the metal sheet that sits between the inner pad and the piston? if so yeah its in place.
    whats the minium thickness for a rear VS rotor??
  4. jules
    pimpin
    not sure.
    the other reason is just that the wear profile on the disc is different from the new pad (which is flat). in time it may bed in and stop squeaking.
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    The rough area on the pad could just be inconsistent pad composition when manufactured. It may contribute to squealing. The reason pads squeal is vibration. It sound's as though you may have a sticky slide or the piston isn't retracting far enough when you release the brakes. Simple fix is to remove the caliper and clean up and regrease the slides with something like never seize. If it is the piston, then you will need to put a kit through it, which is just replacing the rubber O ring inside the caliper and the dust seal. Because the noise is like squeak squeak squeak....you rotor is warped or it has heat spots, the thickness isn't uniform through out the whole disc.
  6. r_i_d_a_h
    ahh yes i recall now, i had a mechanic take it for a drive and he mentioned that i need to regrease the slides. a diagram/picture of the 'slide' would be helpful...
  7. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    The slides are the pins that the two parts of the caliper move in and out on. They are bolted to one half and slide into the other half. Once you unbolt the caliper from the car you will see what the slide is.
  8. r_i_d_a_h
    i took off the caliper yesterday and to my find i noticed that only the top slide-pin pulls off and the one on the bottom is like dead-set stuck, i cant seem to pull it out or is this normal?
  9. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    No, it means the slide is seized. You will have to get it apart, usually with a hammer, but gently, and the clean all the grey looking crap out of it, wet'n'dry the pin so it's shiny, then re grease them.
  10. r_i_d_a_h
    any tips on how to clean the housing in which the pin slides in?? and on the subject which brand of pads is most suitable for my VS? ..regular driving condtions through town with least brake dust?
  11. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    I use a piece of rolled up wet'n'dry and water. Usually cleans it up pretty good. Wipe as much of the crap out with a rag first. Put the rag over a small screw driver and twist it around in there. As for pads, I do RDA pads for $25 plus postage. Not much dust, pretty good pad.
  12. r_i_d_a_h
    thanx a heap for that! just asking, how much for a rear set to suit soild axle?
  13. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    They would be $25 plus postage. I would probably say around $6 or $7.
  14. r_i_d_a_h
    would you happen to have bendix 'premium'? and do you have rotors to along with aswell?
  15. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    I mainly do RDA pads, the compounds are just as good as Bendix, Ferodo and a lot of the other general duty pads on the market. I do rotors too, $40 each.
  16. bradcad
    bradcad New Member
    VT Berlina & mazda 2 DE
    Yeah I've got to say with bendix pads- I really dont know if they have changed but I had the Ultimate Policepads. Stopped like crazy but dusted like insane. When I got sick of wiping the mags down dayly I ended up with a crust of dust ready to be polished off. A couple of hours work to look forward to!
  17. r_i_d_a_h
    so would you guys strongly recommend RDA's?
  18. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    I would say they are just as good as any other general use pad. I have never had any problems with them, and they produce less dust.
  19. r_i_d_a_h
    with rotors, my VS has 10 holes on each rotor, i heard from this forum that its recommended to purchase the same type or is the 10 holes standard with every VB-VS rear rotor?
  20. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    You have drilled rotors? They are not standard. Are they slotted too?
