I'll check out my parts manual.
Update.
Well I've just looked in the illustrations section and it clearly shows a short hose going from the booster fitting across to the back of the plenum. This is exactly as I recall it on my VL Berlina when I changed my standard booster to the larger twin diaphragm VH-512 unit that is fitted on Turbo and V8 models with the 4 disc brake set up.
What I feel you have is the V8 hose which is rather lengthy as it goes from the booster to a vacuum fitting mounted in the valley (inlet manifold). Alternatively it could also be an original turbo hose which is quite long but it is supposed to have a loop in it thus making it much longer than the standard NA RB30 that just jumps across from the booster to the plenum.
One must ask the question is what you have there as a car all original or something that's been played with by some kid that's been mixed and matched to whatever works, this is probably what's leading you up the garden path to the land of confusion.
