I can take the top of the caliper off its just the caliper mount that I can't get off because there's not enough room to get a torque wrench on it due to the strut being on the way @rambunctiousReally !!!
Bolts on the rotors.
What bolts are you referring to ??
If you are referring to the calipers it does not sound right to have to remove shocks to get at the calipers so the rotors will then come off.
Keep in mind the rear rotors are often held tight by the hand brake drums.
Are you sure you are looking at the right things ?
