Brake upgrade from SSV to SSVR Brembo's - Take 2
Discussion in 'VF Holden Commodore (2013 - 2017)' started by jono67, Mar 12, 2019.
  1. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    No, it looks about the same clearance on a VE Redline with the standard alloy's.
    jono67 likes this.
  2. gfl
    gfl Member
    Gen-F Tourer
    Don’t sweat it. Lots of miles, no dramas with a credit card between wheel and calliper. I’d post picture but cannot find a way to reduce file size on phone.
    jono67 likes this.
  3. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    How much do wheel spokes actually flex? Not much I’d guess.
    But consider the spoke to caliper clearance in the standard redline brembo setup.
    My MSE has 5 or 6 mm spoke to caliper clearance at the front wheels and 15mm at the back wheels. I’d think anything much less than the standard setup, especially just 1mm, would be concerning unless you can answer the question how much do wheel spokes deflect during max braking effort from max speed into a tight left and right corner.
    jono67 likes this.
  4. Skylarking
    Downunder
    But not all wheels are the same. Drop forged are supposedly stronger and lighter than various types of cast wheels. Question is, will the different construction impact wheel flex?
  5. jono67
    jono67 Active Member
    2015 VF SSV S1 M6
    Yeah that's the million dollar question, how much do they flex!!! I won't be doing track days, but there are the odd occasions when I give it a bit through tight corners.
    The MSE's have the HF-20 rims right? They were the wheel I was going to purchase, but after having worked out mine had a 48 offset decided to keep them.
    Ron Burgundy likes this.
  6. jono67
    2015 VF SSV S1 M6
    So gfl your Redline only has that much clearance??? Are they standard rims and brakes? Prior to fitting my brakes, I had looked at Redlines in the street and noticed the clearance was not much, but a good mm or two more than I have.
  7. 3rspecB
    3rspecB Well-Known Member
    VF2 SSv Redline, White Manual Sedan
    Here's a quick pic of Front Brembo caliper behind cast MY17 VF2 19" Redline rims.
    My ruler showed 4mm clearance.
    Anthony121, panhead and jono67 like this.
  8. jono67
    2015 VF SSV S1 M6
    Thanks for that mate, yeah that looks about right (ie looks like 4mm). Seems to be varying gaps depending on which style of rim, as I've seen some Redlines which look closer than that.
    My mechanic who fitted the Brembos for me agreed that the clearance was not great, but he reconed that unless a wheel bearing goes, in his opinion he thought I'd be ok.
  9. Skylarking
    Downunder
    Yep, million dollar question which i'm sure Holden engineers know the answer to for the various wheels they've used on their cars.
    Whatever Holden fitted to my MSE is what they have on them. All i can say for certain is that they are round 20" diameter and get very dirty very quickly o_O
  10. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    If it does not scrape it's good. No problem to solve.
    If it scrapes report back and I am sure we will all have something to suggest :)
    jono67 likes this.
  11. gfl
    gfl Member
    Gen-F Tourer
    3 piece Simmons over standard HSV APs. Pic below (yes I know they are pretty grubby).
    jono67 and panhead like this.
  12. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    I don't believe it's a problem, I've had miniscule clearance with some rims and never had the caliper come in contact with the centre spokes.
    It takes a lot off force to flex a quality rim.
    If it does rub you'll feel it through the steering wheel and should slow down accordingly then you'll need to shave a bit off the caliper to correct the rub mark and have it repainted.
    jono67 likes this.
  13. jono67
    2015 VF SSV S1 M6
    Geez, yep, that's pretty much what I have gfl. Appreciate the pic mate, you have made me feel at ease a littleo_O
  14. jono67
    2015 VF SSV S1 M6
    Cheers panhead. I guess I'm about to find out if I'll have any issues as I've got a 1500km round trip coming up over Easter. All highway km's so won't exactly be putting much sideways force through the wheels though.
  15. jono67
    2015 VF SSV S1 M6
    Just an update after returning from my trip. No clearance issues to report. Mainly dual carriageway-freeway, but 200km of the trip was on some pretty ordinary (sometimes windy) and bumpy country roads.
    I did chat with panhead who didn't think I'd have an issue, but he suggested I speak with a guy who used to manufacturer wheels here as he had dealt with him in the past to get his thoughts. This guy (and panhead) didn't think I'd have any issues even though the clearance is small. For peace of mind he said it wouldn't be an issue if I had a mm or two machined off the rear of the spokes locally. Given their advice, and my road trip, I'd prefer to leave the wheels as is, so for now that is what I'll be doing.
    Below is a better view of the clearance (or lack of), pretty tight I know. As you can see, it really is just that local pinch point closer to the hub. Given these wheels are powder coated as opposed to Nenad's which aren't, it looked like he may have slightly better clearance than mine due to that. I noticed a chip in the coating on the inside of my rims the other day when I had them off, and there is what looks like about 1/2 to 1mm thickness in coating.
    panhead likes this.
  16. Rolfie
    Rolfie New Member
    2017 VFII LS3 SSV Redline Commodore Sedan
  17. Rolfie
    Rolfie New Member
    I'm very new to the Forum so please indulge me a little. On the upside I've just recently converted from a long list of hipo GT Falcons to finally sample a product from the other side of the fence. And it was a great move!! Now here's my question. I have a VFII LS3 Redline Auto Commodore sedan fitted with the OE 4 piston Brembo's at all four corners. BUT I want to upgrade the rotors all round with top of the range DBA kit (already sourced). And upgrade the front red 4 piston Brembo callipers with the 6 piston red Brembo's as fitted to the VE's. My problem is I can't find the 6 piston callipers anywhere and my go to Holden HSV parts outlet don't "seem" willing to help me. I've already got the larger DBA T5000 two piece slotted rotors. I'm just trying to locate the red 6 piston callipers. Starting to feel like I'm p*** ing into the wind. Is there anyone out there that can provide some help in this search?
  18. Ron Burgundy
    NSW
    VF II SS
    Holden does not sell 6 piston brembos. They never came on VE or VF.
    Silver VE calipers are the same as VF calipers..
    People normally get 6 piston calipers from the states.
    https://zzperformance.com/products/g8-front-brembo-6-piston-caliper-brake-kit
    PS. You will also need bigger rotors for them...
  19. kleanphil
    kleanphil Active Member
    G.C.
    VF SS-V SII Sportwagon
    Wow , the price of that kit in AUD is only a few hundred more than what I paid just for the DBA discs I bought for my 6 pot Brembo's , then I paid that again for the calipers , I must be missing some thing , would like to know what delivery would be for that kit .
  20. kleanphil
    G.C.
    I think HSV used AP and Harrop calipers , I'm not sure which come in 6 pot , I think both were 4 pot
