Brake upgrade kits
Discussion in 'VE Holden Commodore (2006 - 2013)' started by mark7, Jun 25, 2015.
  1. mark7
    mark7 New Member
    QLD
    06 VE V8 Calais V/ 08 VE Omega
    I'm looking at upgrading my brake calipers, pads and rotors on my Calais in the near future and I am wondering what deals there are out there. Currently thinking of going 4 piston front and rear calipers with some slotted rotors. For the most part its a daily driver with maybe the odd track day in the future after some engine work.
    What are some options that wont break the bank? Anything possible for the 2K mark?
  2. brasher
    brasher New Member
    Aus
    VE SSV Ute
    I got the brembo 4 pots and 355mm disc for $800 through Thompson Holden. Best mod I've done to be honest.
    With some QFM pads I nearly headbutt the steering wheel when jumping on the pedal.
  3. Towcar
    Towcar Well-Known Member
    Auckland NZ
    VX Berlina Wagon
    Depends on what size rims you have and their offset, as you wont get much for 2K if you need rims as well!
  4. SnowDoggyDogg
    SnowDoggyDogg 2ltr? = Only milk & juice
    Goldie
    Gen F GTS
    I sourced my 4 pot Brembos (Camaro) rotors (DBA slotted) and rims (Camaro)all around for $2k. Another $300 was spent at the garage for putting them on. It can be done if you are savvy enough to do the research and fitament yourself.
  5. mantaray56
    mantaray56 Active Member
    Ballarat
    VE II SV6 Z
    Yeah Holden made it hard for us by only making HSV 19 and 20 inch wheels fit Brembo's( Camaro's) -My 19 inch SSV wheels won't fit-bummer
  6. kuzman89
    kuzman89 Active Member
    vic
    VE SV6 ute
    I got a quote last week for 4 pot brembos and DBA slotted all around.
    $1100 for brembos
    $1,000 355mm rotors, or you could get a cheaper set of rotors on Ebay.
    Quote was from revhigh.com.au
  7. mark7
    mark7 New Member
    QLD
    I got 20 inch aftermarket wheels on it already, cant remember the offset though can't imagine they would be a problem if I stick with 4 piston calipers.
    I'm not confident enough to do the work myself so will get my mechanic to do it next service. I found a kit from Empire Performance that looks like it has calipers of the 4 piston CVT-S with RDA rotors that looks alright.
  8. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
  9. mark7
    mark7 New Member
    QLD
  10. SnowDoggyDogg
    Goldie
    Gen F GTS
    The RDA rotors are pretty average as I had some on my G6Et and they warped within months.
    I'd definitely look to getting DBA 4000s which are roughly $215ish per rotor for the T3.
    I used my existing OEM brake lines as I was advised braided were a tad overkill.
    Car pulls up hard with no fade on continuous spirited driving in the hinterland.
  11. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    You should do yourself a favor and get some braided brake lines. Makes a huge difference to the pedal feel.
  12. mark7
    mark7 New Member
    QLD
    It would come out around the same price as RDA then, I would rather DBA over them though.
    These
    the ones you are talking about?
  13. arronm
    arronm Active Member
    FPV F6 VF Redline WGN
    I agree get DBA4000 T3 discs and braided lines. Completes the package well. DBA now make the correct 355mm rear discs. I use QFM HPX pads
  14. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    GSL Rally sport helped me out for rotors when I got the CTS-V Brembo kit. I'd go a 2 piece front and 1 piece rear. Will come in under $1000 if prices haven't changed much. T3 ftw
  15. Smashfist
    Smashfist Active Member
    SE QLD
    440rwhp Cammed VF Ute
    If you're going through the work of changing calipers I'd throw braided lines in just because you're there.
  16. SnowDoggyDogg
    Goldie
    Gen F GTS
    The correct parts numbers for the 355mm DBA slotted rotors are:
    DBA42604S (fronts)
    DBA42031AS/BS (rears)
    Replace the 'S' at the end with 'XS' for cross drilled slotted rotors and if you want the two piece rotor than replace the '4' after DBA with a '5'.
    GSL carried the rears which ran about $240ish per rotor and I found a shop (off ebay) who was just around the corner from GSL who sold me the fronts for $200 each. GSL wouldn't price match the complete set unfortunately but I saved about $45 looking around for the fronts which are more common.
  17. arronm
    The 5000 series are quite expensive and only really worth it if you are hitting the track. Braided lines are money well spent.
  18. chargedvx6
    Agreed on the 5000 being more expensive. Future rotor replacements are cheaper however so imo cooler and better quality semi floating parts that will pay off over a few years.
    Amen to braided lines!
  19. mark7
    mark7 New Member
    QLD
    I was umming and ahhing about braided lines but you people have won me over. I don't want to half arse it only to regret it later on. I'll keep an eye on the rotors Snow linked as they came to around $950. There's a shop I was going to price up the engine mods I want done so might see if they can do me a better deal.
  20. arronm
