VZ1CAR59
- May 12, 2021
- 63
- 36
- 18
- Age
- 21
- Location
- Perth
- VZ SV6 05
Afternoon all, looking at doing components of my brakes and suspension over next month or so. Figure doing them in one go would save a bit of time. Few questions, (my car is VZ SV6 2005)
The shock absorbers are pretty worn all over. Looking at replacing these starting with front and then on to back. Reasonably happy with fe2 factory suspension but Holden no longer sells for parts for them. What in your experience is the best shockies?
As for the brakes from what I understand the go to is DBA slotted rotors and whatever brake pad you chose will be alright provided they aren't cheap eBay junk. I know the pads are worn but the discs seemingly have a good bit of life left in them. Both are at 27.8 mm and min is 25mm. My question is how much life do these discs have left in them/original manufacturer size. I dont mind replacing them if they're due in within a year but they seem to be quite healthy right?
Finally I'm wanting to take on the outer suspension cross member bushes. They are cracked getting lots of movement. Whats the experience with urethane vs factory rubber? A quick run down of the job would be great.
There's loads of how tos so I'm gonna try just work it out for myself but a heads up in regards to any issues I will come across would be great.
Cheers fellas, apologies for rather simple questions
