Brakes Screetching and heavily grinding!
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by social, May 17, 2012.
  1. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    Hey guys recently sprayed my calipers and rotors, sanded down the rotors so no surface rust and glaze with a 120 grit sandpaper. Now I've got really loud grinding in the rear on the pads, horrible sound and when I'm slowly rolling at 5kmh I can hear it grinding too.. Solutions!?
  2. KAL SPL
    KAL SPL Member
    Orange Nsw
    Blown VS Calais !!
    Stop doing work to your car ?
    But seriously , you sanded the surface where your pads actually grab ?
  3. somefool
    somefool Member
    Adelaide, SA
    1991 VN 'S', 1997 Ford Laser 1.6
    try bedding them in again.
    I would hope ya didnt sand them down so to speak. but rather 'roughed up the surface a little'
    did it squeal or grind at all before u did this work?
  4. puhz
    puhz New Member
    QLD
    VY UTE
    I'd suggest getting them machined properly it doesn't cost that much:surprise:
  5. KAL SPL
    KAL SPL Member
    Orange Nsw
    Blown VS Calais !!
    You will probably have to replace the pads given they now have paint melted to them if you didn't mask up your discs before painting.
  6. social
    social Ute Finatic
    South Aus
    Yes I did sand the surface of where they grab, no they didn't do this before and I masked tediously up all areas before spraying, mayb I roughed up the surface too much...
  7. social
    social Ute Finatic
    South Aus
    If I take them off and get a 400 grit paper to them n smooth it off more will it help? Also will a smooth off of the brake pads surface help?
    Remembering I did the fronts the same and they're fine..
  8. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Good lord. Take it to a brake place and get them to have a look. No offence but you obviously don't know what your doing.
  9. KAL SPL
    KAL SPL Member
    Orange Nsw
    Blown VS Calais !!
    Just wow ...
  10. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    Maybe have a look to see if you put a pad in backwards
  11. social
    social Ute Finatic
    South Aus
    I don't see where a mistake has been made, what is wrong with sanding the surface ?
  12. richardpalinkas
    Gold Coast
    Was it just a light sand? Why did u sand the face of the rotor?
  13. Jesterarts
    2010 Nissan X-Trail ST-L
    Nooo... stop sanding the damn things. The damage is done.
    Read this thread, the last page or so in particular:
    http://forums.justcommodores.com.au/general/195169-using-sandpaper-roughen-up-brake-rotors.html
    In your case, take the rear apart and make sure there isn't any crap on the rotor or pad surface. Make sure it's all in the correct way and see how you go.
    If you are still getting an issue, take it to a brake place.
    What is with people sanding rotors lately??
  14. social
    social Ute Finatic
    South Aus
    Was just taking surface glaze off jester. Just bought new rotors and pads and found if put a pad on backwards... That's wat caused the problem.. Accidental mistake
  15. Jesterarts
    Glad you've got it sorted mate.
  16. social
    social Ute Finatic
    South Aus
    While everyone's all knowledgable on the subject, can I use htb high temp bearing grease on the pin guide? Looks like it could use some, the piece I speak of is what the caliper swings on when u crack one of the nuts to remove the pads, seems tad dry. Htb suitable?
  17. richardpalinkas
    Gold Coast
    Yea that's fine, or that never seize stuff
  18. social
    social Ute Finatic
    South Aus
    the damage
    the goods
    Still cant believe i made such an obvious mistake with a backwards pad.. all fixed anyway.
    the result
  19. richardpalinkas
    Gold Coast
    Make sure to adjust the handbrake too. Adjust it so you can just hear the handbrake shoes rubbing the inside of the rotor without too much resistance
  20. social
    social Ute Finatic
    South Aus
    ive been meaning to adjust my handbrake cos it doesnt engage enough, gatherings its the spline through the hole on the rotor?
