brakes squeaking........
MattyVRss
matty T
gympie qld
VR ss
hey guys i have noticed recently that when i apply the brakes coming up to an intersection to stop, when i then drive off it sounds like i may have a brake dragging cause it makes a saueeking sound from the rear of the car? could it be as simple as this? and what can i do to fix it?
leigh 7005
adelaide
vb sle
sounds like you need new brake pads if they are new did they have dust grooves
MattyVRss
matty T
gympie qld
VR ss
na pads r ok checked them the other day and there is about 3/4 pads still.. it alomost feels like its dragging a brake somewhere also when u take off....
Hunter SS
Growing Old Disgracefully
Upper Hunter Valley NSW
2006 VE SS
did you check the shims that go around the pad? there is a tab that folds over to hold the shim in place, this may have moved.
Hunter SS
2006 VE SS
whoops, sorry, i was thinking of the shims in the VE... but i'm pretty sure you have shims in there somewhere... see if they are rubbing.
MattyVRss
matty T
gympie qld
VR ss
ok i will have a look i havent really had alot of experience with brakes other then bleeding them and replacing one set of pads on the rear of my ute other then that i have neva had brake issues before lol
Tas_HSV
Hobart,TAS
VR HSV Clubsport
when driving,if you apply the handbrake a bit,do you get a bang?
HSV472
i just got one
s.e melb
hsv vr clubsport
oh i got this problem to its like a lite rubbing noise?
tas hsv yes mine does can you explain why
