Brembo 6P/4P upgrade 2016 SSV
Discussion in 'VF Holden Commodore (2013 - 2017)' started by woooo, Feb 11, 2018.
  1. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    Here's a reasonable rundown:
    Drilled or Slotted Rotors — What are the Best Brake Rotors?
    http://www.autoanything.com/brakes/drilled-or-slotted-rotors-what-are-the-best-brake-rotors.aspx
    And here is what DBA have to say:
    Should You Opt For Slotted or Cross-Drilled Rotors?
    When replacing an essential performance and safety component on your vehicle like your brake rotors, it’s important have all the facts at your fingertips.
    Knowing the performance and ventilation differences between slotted and cross drilled rotors will help you make the right decision about which disc brakes suit your needs.
    Every time you engage your brakes, gas and debris collect between the brake pads and rotors. Over time the build up can cause your disc brakes to overheat, warp and even crack. To expel the built up debris and gas rotors come in slotted and cross drilled designs to give you a safety and performance advantage.
    The decision as to whether your discs should be slotted or cross drilled depends on the vehicle use, performance aspirations and vehicle style.
    “If your brakes are working hard for their money and you want nothing but the best, invest in T3 slotted rotors. If you’re looking to complete that show car look, but still want the street performance and safety advantage, go for the cross-drilled rotors, ” said Martin Peart, Director of Sales at DBA.
    If you drive hard, race or use your vehicle off-road or for towing purposes, DBA recommend installing slotted rotors, as the surface grooves make for cleaner rotors and effectively reduce overheating in demanding conditions.
    DBA’s top of the range T3 slotted disc brakes offer greater pad bite for improved stopping performance, and the peace of mind that comes with purchasing a quality Australian made product. The T3 range is designed to handle harsher conditions and have been installed in every Australian V8 Ute race car, a testament to their quality and performance.
    Any auto enthusiasts looking for a high performance looking disc brake to improve the aesthetics of their car should opt for cross-drilled rotors. Put simply, they look sharp and perform well. These will look the part on street cars or show cars.
    “Performance disc brakes are cheaper than ever as competition in the market has driven down prices. The concerning fact is that many people are looking overseas for a lower price over a quality product where their safety is concerned.”
    “You can’t put a price on your life, so if you’re driving hard, invest in top quality Australian disc brakes.”
    Video:
    Drilled, Slotted & Vented Brake Rotors - What's Best?
  2. saroadie
    saroadie Active Member
    2015 VF SV6 Storm
    I don't think DBA make a 5000 series 2 piece rotor for this application (except replacement ring for C7 Z06 Corvette on a made-to-order basis - mega bucks but even then I don't know what you'd do for a mounting bell).
    For 370mm 6-piston application in DBA it's the 4000 series one piece. Produced in T3 slotted (best performance) or slotted and drilled (blingiest). I think they're available in street series T2 slotted as well. Probably depends on what's available for the rear to match.
    For cheapest 2 piece it's OE (which are neither drilled nor slotted) as Monstar says or it's Brembo (which are slotted) and mucho $$$$ - both from USA.
    On the slotted vs drilled, I agree with the consensus. Slotted for track or bling, drilled just for bling. Plain would be OK too - at this size brake, if you're running out of whoa on the street and you're not towing down a looong hill, you won't have a licence or a car for long.
    woooo likes this.
  3. EternityDre
    EternityDre Well-Known Member
    Melbourne, Victoria
    MSE #385
    Quick question, if slotted is superior to drilled why do all high end super/hyper cars have drilled rotors instead of slotted?
    426Cuda, Tonner Matt and woooo like this.
  4. woooo
    woooo Active Member
    Australia
    Multiple
  5. panhead
    NSW Central Coast
    Cars
    Form over function is often the reason given.
    Yet there are other theories on the subject that fall outside the usual slotted is better than cross drilled because cross drilled crack easily.
    Carbon-Ceramic brakes which are often on high end cars have very different heating properties to standard brakes and are less prone to cracking and they tend to have very small holes compared to what you see from the mass produced rotors.
    A part from the size of the holes there are rotors where the holes are drilled and rotors where the holes are cast.
    Both my AMG’s come with cross drilled front rotors and crossed drill and slotted rears and I would have thought it would be the other way around.
    One thing I notice on my AMG is the holes in the front rotors are not in a uniform pattern like I see on some cars.
    In some places the holes are within a millimetre of the rotor edge and the holes vary in sizes and not all holes go all the way through.
    I don’t know if they are drilled or caste but I do believe they are there for looks and not function as it’s a street car not a track car and if I’m getting myself into multiple situations where the rotors are glowing red hot on the street causing premature cracking then I should be sent to gaol.
    Front
    Rear
    The other rotor no one has mentioned that is becoming popular is the J Curve.
  6. saroadie
    2015 VF SV6 Storm
    42068S is the part you're after.
  7. saroadie
    2015 VF SV6 Storm
    Maybe the AMG rears are slotted because they'd be most prone to glazing?
    By J curve do you mean fish hook shaped? This type has been in use in racing for ages.
  8. woooo
    woooo Active Member
    Australia
    Multiple
    Lorem ipsum porta eros etiam ultricies ipsum vestibulum, quam nisl dictum venenatis justo non, nunc orci massa inceptos id ad cras dolor aliquam dictumst nulla cubilia et, quisque sociosqu aliquam eros nam arcu, massa feugiat pellentesque tempus ut purus vitae in ultrices conubia mollis aliquam lorem commodo volutpat vivamus, dapibus nam tristique sem luctus tincidunt ante gravida morbi elementum molestie nam felis sollicitudin per fringilla tincidunt, proin placerat morbi nam sem eu.
  9. saroadie
    2015 VF SV6 Storm
    Yep.
  10. woooo
    woooo Active Member
    Australia
    Multiple
  11. saroadie
    2015 VF SV6 Storm
    You're after a Redline 360mm rear.
  12. woooo
    woooo Active Member
    Australia
    Multiple
  13. panhead
    NSW Central Coast
    Cars
    Yes they've been around for a fair while in racing and having looked them up they are more commonly known a 'J Hook'.
    They've also been available in very limited numbers for street cars for a while but are now starting to be seen more and more on higher end cars and being supplied for street duties by the manufacturers.
    And a drilled carbon ceramic rotor
    monstar likes this.
  14. NeddyBear
    NeddyBear Veteran Mountain Biker
    Queensland
    2004 Subaru Outback 2.5 & 2002 VX II Acclaim
    During the cooler months we tow a camper trailer and when fitted the slotted rotors straight up I could notice the better stopping power.
    Fitted them about 4 years ago and the wear has been excellent.
  15. arthurk
    arthurk Active Member
    SSV Redline VFII / SSV Motorsport KOM0993
    My 911 had cross drilled - for road use they were fine and really they are there for cosmetic reasons. Once on the track I did crack them so on the Redline I am going slotted as it will be my new track/daily car. My Motorsport has the cross drilled rotoers on it and it really is cosmetic.
    I too am looking at the CTS-V upgrade but havent pulled the trigger on the kit as yet. As a matter of interest have you installed the rears as yet and have you had them replumbed? I believe you need to reverse the plumbing as they are mounted differently between the CTS-V and the Commodore - leading vs trailing calipers. I am also interested as to where you sourced the kit from and how you found dealing with them if you are ok with sharing that information.
  16. saroadie
    2015 VF SV6 Storm
    Try DBA42074L and DBA42074R.
  17. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    Oh yeah, dba do quite a bit made-to-order, my rear rotors were and became a huge success with the G8 crowd.
    The 4p T3 5000 I have now were also custom made to order, just wanted me to get the T3 slots as well not plain which I wanted. No biggie, not that much dearer when you view the cost over 150-180k km.
    saroadie likes this.
  18. woooo
    woooo Active Member
    Australia
    Multiple
  19. woooo
    woooo Active Member
    Australia
    Multiple
    Sit gravida et nostra donec felis posuere id magna, purus lorem nulla ultricies hac et etiam varius imperdiet, etiam enim conubia augue tristique dolor tempor curae tristique morbi taciti per condimentum fames etiam fames etiam dolor, pharetra dictumst gravida neque accumsan viverra donec enim massa cubilia, fringilla consequat quisque class cursus volutpat dolor egestas porttitor leo adipiscing tortor mattis litora ultrices aliquam eros condimentum ultrices bibendum est dui platea.
  20. woooo
    woooo Active Member
    Australia
    Multiple
