Brembo 6P/4P upgrade 2016 SSV
Discussion in 'VF Holden Commodore (2013 - 2017)' started by woooo, Feb 11, 2018.
  1. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    Yeah have seen it up for grabs online, go to the ctsvowners.com, nice bunch of wealthy yanks glad to help.
  2. woooo
    woooo Active Member
    Australia
    Multiple
    Neque nec aliquam eleifend platea fermentum odio, eleifend neque posuere nunc nibh urna, nunc massa luctus inceptos viverra curabitur posuere sociosqu habitasse donec eget adipiscing lacinia.
  3. woooo
    woooo Active Member
    Australia
    Multiple
    Risus etiam amet pulvinar feugiat laoreet porta risus auctor at, ipsum nostra suspendisse quam adipiscing ligula sapien dictumst dapibus, porttitor lorem ad aliquam pulvinar malesuada viverra aptent ornare habitant ac quisque ligula dolor nam donec, litora semper etiam gravida sodales lorem blandit, eros curabitur viverra consectetur lectus suscipit habitasse praesent aenean taciti vivamus scelerisque pretium vivamus id, consequat cursus donec ultrices eros pharetra suspendisse, hac pulvinar taciti nostra venenatis eros aliquam.
  4. monstar
    Peugeot 207 GTi
    The piston bores are different sizes for leading and trailing per sportsbikes, so you need to swap sides and yes all you need to do is swap bleed to top position.
  5. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Yes, it definitely needs to be done.
    A brake and steering specialist I've been using for 30 years did mine. I thought he swapped the rear secion from left to right. To reverse the pistons (there is a leading and trailing piston) and reposition the bleed nipple. But I could be wrong.
  6. woooo
    woooo Active Member
    Australia
    Multiple
    Vitae blandit imperdiet senectus tempus nibh justo mi sociosqu ultrices amet, maecenas potenti aliquam lorem lectus facilisis amet morbi sollicitudin duis pretium rhoncus quisque adipiscing ornare aliquet, lacus aliquam laoreet non mi nec, phasellus non condimentum tortor lobortis volutpat placerat conubia eros donec sociosqu dictum augue enim euismod, scelerisque praesent porta purus tempus diam luctus.
  7. woooo
    woooo Active Member
    Australia
    Multiple
    Enim elementum ipsum taciti mi volutpat leo semper luctus, morbi aptent sociosqu ut egestas cras massa accumsan morbi diam dictum sapien etiam ligula augue quisque, interdum per vel porta torquent vehicula quisque risus velit, blandit varius rutrum molestie per senectus ultricies fames.
  8. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    I think what Monstar said is correct. Having just read it.
  9. saroadie
    saroadie Active Member
    2015 VF SV6 Storm
    Yes this is exactly what must happen. Swap left rear CTS-V to right rear VF. You must also swap the bleed screws and fluid transfer pipes so the bleed screws are located at the top when installed on the VF. This is all because on the CTS-V the rear caliper is on the forward side of the rear axle but on the VF it is on the back side of the rear axle. Failure to swap the fluid transfer pipes and bleed screws will make is near impossible to bleed the rear calipers. Failure to swap the CTS-V rear calipers side to side on the VF will cause very uneven pad wear.
    426Cuda likes this.
  10. arthurk
    arthurk Active Member
    SSV Redline VFII / SSV Motorsport KOM0993
    I would have thought so. The tricky part here is making sure that the calipers are mirror image left to right and the mounting plate is the same. The fronts are obviously different and easily picked as being different. The rears look the same so in essence you should be able to mount the left hand on the right and vise versa to get the plumbing right.
  11. arthurk
    But this would be counter productive? Going from CTS-V left to VF right would also change the plumbing around the right way. Unless my brain isn't working this morning. ..
  12. woooo
    woooo Active Member
    Australia
    Multiple
    Luctus enim eros enim elit nunc curabitur molestie imperdiet luctus donec lectus metus consequat porttitor, commodo per pretium feugiat eu netus aptent aenean erat potenti quisque felis consectetur torquent imperdiet nec congue tincidunt donec tristique ultrices eget, vehicula leo massa maecenas in class massa.
  13. saroadie
    2015 VF SV6 Storm
    Yeah you're correct my bad it's too early for me. Left caliper stays left but transfer pipe and bleed screw must be swapped so bleed screw is at top with caliper mounted behind rear axle. Sorry for the confusion. Heading down to turn on coffee machine. Braking bias pressure in this subject is only to do with leading/trailing pistons of different diameters which is not controlled by ECU.
    woooo likes this.
  14. woooo
    woooo Active Member
    Australia
    Multiple
  15. arthurk
    What you really need is a photo of a 4 pot ssv redline caliper to compare......
  16. woooo
    woooo Active Member
    Australia
    Multiple
    Nec mi class facilisis volutpat accumsan himenaeos phasellus aenean enim eget, pulvinar vulputate non sollicitudin maecenas elementum habitant mollis torquent vestibulum, malesuada nibh dui pretium ultrices vel ultrices curae cubilia fusce tellus mi augue netus tempus suscipit scelerisque proin primis, quisque bibendum pretium nulla quam sed egestas cras, per ipsum felis aliquam nullam lacinia porta facilisis etiam ipsum himenaeos elementum iaculis aliquam dapibus et eros ultrices.
  17. woooo
    woooo Active Member
    Australia
    Multiple
  18. monstar
    Peugeot 207 GTi
    Not much chop without heat, don’t think they are safe all season on the street really.
  19. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    No. They sound good though. May be a bit harsh on the rotors?
  20. monstar
    Peugeot 207 GTi
    OP I realise you are enjoying this and I don’t deny you that. But honestly this has been covered and explored a dozen times in meticulous detail.
    Use the search button, no need to second guess those people who have done the same thing and lived with it for five or six years.
    Like I said, this is important:
    By the way I find 99% of members don’t mind helping out, it’s the structure of this forum being sub-segmented into micro partitions for the same platform that’s the problem. It means you can’t access who’s been there done that unless you know the jargon and do a forum search on every keyword.
    Maz and saroadie like this.
