dgp
- Jan 1, 2011
- 1,462
- 571
- 113
- Location
- Victoria
- VF II SSV Redline
Hi all,
The clear coat on my VFII Redline (left hand side only) calipers is peeling. Holden in their wisdom believe this to be fair wear and tear given the heat cycles the calipers go through. I called BS on this as it should be both fronts failing then, not one front and one rear. Anyway, warranty denied. Oh, the car has 67,000km.
I am looking for some advice, to understand if I can use a pressure pack clear coat to spray over these degraded sections to seal them up. Would this be acceptable or would it just create a seam between the existing clear and new clear?
Appreciate any feedback.
Rear
Front
Rear
Front
