broke bolt on engine mount
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by bard, Dec 16, 2016.
  1. bard
    bard New Member
    Ballarat
    94 5.0L Ute
    Over tightened the front mount and sheard the bolt that mounts to the block. Any suggestions on how to get it out? Its also leaking a bit of oil
  2. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    If you've overtightened into the block there is a chance you've done damage to an oil gallery.
    You're going to need to use some form of extractor to get the remaining thread out so engine removal might be your next step.
  3. strgas
    strgas GRA = REAL HP
    right angle drill ezi out and loctite replacement bolt to block should stop the oil leak have fun .........
  4. kiwicon
    kiwicon Active Member
    NZ
    VS V8 Manual
    or a reverse threaded drill bit...
