Hey guys, I was wondering if anyone had replaced the exterior drivers door handle before? Many have replaced the passengers but the drivers is bit more complicated, the bracket inside is broken. ANY help would be much appreciated Thanks in advance, Mike.
I'm pretty sure once you take off the door trim, you will see a sliding pin to the side of the inside of the door handle. Once you slide it out, the handle falls off. Hope this helps
