simon.w
- Sep 5, 2007
- 332
- 10
- 0
- VE SSV
Hi all,
For those of you with the roof-mount TV/DVD in your VE, if the screen ever becomes loose as it folds down, it will be the same problem as I have just discovered.
Normally it folds down firmly, so that you can leave it at the best viewing angle and the hinge is mounted in a plastic cylinder.... about the size and diameter as if you cut 8mm off the end of a ball point pen.
This cracks through.... so rather than the screen pivoting on the metal shaft, the whole lot turns inside of the cracked plastic cylinder.
The tell-tale sign (apart from the screen going loose), is that it forces the join apart at the top right hand side of the screen.
I have fixed it temporarily by removing the top screws under the rubber plugs at the top of the screen, splitting the cover, and putting a cable tie around the cracked plastic mount.
I'll be taking mine back for replacement.... but looking at the poor industrial design, I expect it will happen again.
So... after 4 months and 7500km... I have had issues with:
- specs of dust in the paint causing pimples in the duco
- cracked floor mats
- peeling and cracking track stripes
- broken TV
Don't get me wrong... I love my SS... but the build quality and industrial design is not a patch on the Mazda6 luxury sport that I owned for 5 years previously.
So much for the Billion Dollar Baby Holden!!!!!
- broken TV
