Trevor loves holden.
- Jun 6, 2019
- 3,508
- 750
- 113
- Location
- Victoria
- vs commodore
Gee, this turned into a bitch fight, I only asked if he lived at a wreckers hence he has 3 phase..
Yes my spelling is not good but you seem to understand what I'm saying, all I want is to help people and give them another avenue its then up to the OP either to take it or leave it..
And yes VC I did lay into VIN as he was coming across a bit aggressive, then I changed my point of view once all your close neat group started on me, If you cant handle the backlash then don't dish it out. AS the mod said ignore and move on all this bs can be avoided if your gang just stop starting things and protecting each other putting your noses in. We are all not perfect and said things that didn't help the OP question just like your oil pressure hell VS lover saying a Intake manifold gasket is the reason for a rough idle when it has no effect bar oil in coolant or vice versa. I said many of times unless the car is in your drive way its just speculation assuming the issues.
Every bit of info can lead to solving a problem right or wrong, bottom line taking it to a mechanic is a best option on most cases you can spend triple the amount of money replacing unnecessary parts.
