Zuicider
Banned
- Dec 17, 2005
- 1,740
- 18
- 0
- Location
- Stonedville
- Set of thongs
haha looks like my vn, imperial blue with paint missing all over it
Looks good, except for the bonnet. Sorry, Im abit fussy when it comes too paint. Is there a clear coat on it? If there is, I'd suggest wet sanding it with 1200 grit wet 'n' dry and going over it with rubbing compound and polish. It'll make it come out real nice. I sprayed my old 1988 Subaru with a Metallic gold and clear coat and it turned out real nice after abit of sanding and polishing. Here are some pics:
Yeah the bonnet came out **** house. No idea what went wrong, everything we did was even, i.e sanding, paint light etc. But the clear coat has only made it glossy on one side, and the rest is rough. Als very patchy like light and dark patches. Up close you can see heaps of scratches aswell.... Needless to say its on there because the old one was drawing alot of police attention which he doesnt need, so the new one has been fitted for the time, and we will source another and paint it up.
Good work on your Subby to, came up nice.
Thanks mate :thumbsup: Sold the Subby about 6 months ago for $2500 and then bought the commodore. If its a metallic paint I think I have an idea on your problem. What you have to make sure you do with Metallic is spray it in one direction only and keep a constant movement when painting. If you hesitate or stop when when spraying it will make it patchy because the metallic flakes in the paint will bunch up. Also the metallic flakes in the paint fall a certian direction so if you cross the flakes over it gives a rough look and the uneven patches. In otherwords you have a certain grain you have to follow when spraying Metallic. You cant overlap over your strokes at all or go over your original stroke in the opposite direction. Dont feel disheartened though because its very hard to spray Metallic and I guess its better than a rusty bonnet. Well I posted a picture showing what I mean because its hard to explain. Hope this helps if you plan on doing it again
