Brown sludge in coolant reservoir + coolant level dropping
phuecn
VS Vacationer
I am having to fill my coolant tank every two weeks and there is a brown sludge at the bottom of the reservoir. But I am not seeing any other major problems:
i) The engine never over heats.
ii) No smoke or steam from under the hood.
iii) No bad sounds from the engine.
What is the first thing I should check for?
I want to check for a possible leak in the cooling system but I'm not sure where to start looking.
Obviously it would be a major problem if I had a blown cylinder or head gasket - do my problems point in this direction? And if so, how much would it cost to address these problems.
Thanks!
Fenners
Fenners
Boronia
VS II Berlina Wagon
it sounds like a simple leak. brown sludge is the sign of a poorly maintained cooling system. this is not uncommon as it is quiet often overlooked. flush the cooling system and then fill up with 50/50 coolent and water and if a vs bleed the cooling system using the bleed valve. run the car to operating temp and check for leaks. if it was a head gasket the oil and/or water would be a white and milky.
phuecn
VS Vacationer
Thanks Fenners, I'll get onto that. The oil is dark brown, but only because it's in need of a service, so like you said, probably just a leak.
MaxM
VY Acclaim Series 1
slight oily looking sludge in coolant overflow tank in VY
I have the same problem on VY I Commodore Acclaim. I occcasionally see a brown oily looking sludge on the dipstick. I suspected a head gasket, but dont see any of the other symptoms associated with this problem like foamy milk shake or smoke bellowing from the exhaust. Engine temp is stable and teh car runs like a dream otherwise. Could this just be an indiation of the car needing a radiator flush? I noticed oil near the CV joint, could thsi be getting into the radiator?
VZ57SSZ
Central Coast
MY16 VF Series II SSV
Could be the Intake Manifold gasket, they are common and cause a sludge like substance to appear in the radiator and uses water when there are no leaks.
You can flush the system and top it up and if it keeps using water and the sludge appears again it is def that gasket.
JoshSvc
Central Coast, NSW
VN Sedan - The Beige Bandit!
I believe the Holden tablets you are meant to add to the cooling system have the same effect. When i bought my VR wagon i had the same problem i did a flush and it never came back.
Rhin0o8
VZ Calais Impounded?
+1 for this comment .
you have a leak in the Inner Manifold Gasket .
just had one replaced in a VS .
get this replaced before a coolant flush or else it will dirty the coolant again.
should be around $150 for a gasket and 2-3 hours labor .
