burning kind of smell after driving hard?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by onizuka, Sep 11, 2012.
  1. onizuka
    onizuka New Member
    QLD
    VT II SS
    Hi all, just joined this forum.
    Am getting a burning kind of smell sometimes seeing white smoke? only seems to happen after give it a bit.. tonight when i got home, i opened my door and saw white smoke coming from the A/C vents smells a bit like something burning. the other day sitting at the lights i could see smoke coming from under the bonnet.. when i got home white some was rising from the extractors on the drivers side.. only every now and again tho, as if something was dripping on it? any ideas would be muchly appreciated. My car is a VT II SS.
    Thanks in advance.
  2. FATMOE
    FATMOE New Member
    VY Clubsport R8
    Check for oil leaks, are you sure your not smelling brakes? If you drive hard you need to brake hard.
    And I hope nobody on here buys your car if you wish to sell it, stop driving it hard and respect your car lol.
  3. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Could of blown a gasket the way your driving it, degrease your motor, and watch out for oil. Even better if do an oil change as if you cant get rid of old oil marks, fresh oil will show easy on it.
  4. ncass11
    ncass11 Member
    cairns, QLD
    '81 Diesel Hilux / '75 Landrover series 3
    the only thing i can think of is oil leaking
  5. umair
    umair New Member
    saudi arabia
    Sold my car :(
    Change your valve cover gasket. Same thing happened to me, I changed it and problem solved.
  6. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    1.Blue Smoke = Oil = Valve Seals or Rings
    2.Steam = Coolent = Head or Head Gasket
    3.Black = Rich fuel ratio = o2 sensor,spark,air filter,regulator or injectors
    4.White = Oil and Water = Head or Head Gasket
  7. MY_84_VK
    MY_84_VK New Member
    Central Coast
    VK Berlina/VX S Pac
    My car used to do this too, it was just the exhaust it wasn't far off new so it was still bedding in
  8. onizuka
    onizuka New Member
    QLD
    VT II SS
    Hey everyone,
    thanks for the advice.. will check them out. also i don't drive it hard everytime.. i just meant after giving it a bit here and there. I'm sure yous all know what its like to get your first V8.. :p
    cheers again.
  9. Thorbs
    Thorbs New Member
    VT 5.7 Ltr Commodore
    If its white smoke it could be your head gasket, if it's black smoke check your rocket covers they could be leaking oil on to your exhaust,
    Good luck.
    Carl
  10. VS-S-PACK
    VS-S-PACK New Member
    Melbourne, BALWYN
    VT S 5 SPEED MANUAL
    Was my rocker cover gasket, same exact problem
  11. umair
    umair New Member
    saudi arabia
    Sold my car :(
    Sorry in my earlier post I said valve cover gasket, I mean the rocker cover gasket actually. They are both same names lol.
  12. HDT4EVER
    HDT4EVER New Member
    2000 V6 VT S2 Custom HSV
    Yes it sounds like your rocker cover gaskets need to be replaced cause they mite be melted by the way you drive your car. Also have you got water in the radiator ? Check the Transmission fluid from the dip stick and look around the radiator cause your transmission fluid runs thru it.. And the white smoke could mean you've got not enough engine oil or to much and your burning it... Also make sure your A/C system is not leaking gas cause that can be very deadly !! Fire Hazard.. I almost forgot with Holden engines you can't give it to them at all unless you've done work to the engine.. You have to treat your car like a girls body !! Nice sweet and fragile..
  13. DAKSTER
    DAKSTER Beam me up Scotty!
    Woodford QLD
    VS Berlina
    When did AC gas become flammable? If it reaches 250C it can cause decomposition and break down into toxic gases, but its not going to reach that temperature just spraying on a hot surface and evaporating instantly, which it will. Its not flammable at all, so fire hazard - not from AC gas.
    Lots of Holden taxis get thrashed for 700,000 km and still run well. Don't think they usually 'do work' to the engine apart from necessary maintenance either.
    The description OP gave points to oil on the extractors, he just need to find the source of the oil. Oil on extractors will make white smoke, not black. It could be as simple as oil from greasy hands on the exhaust, or paint burning off, especially if the exhaust is new or has recently been worked on, or it may be a leaking rocker cover gasket.
