burnout ute v6 into courier
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
hey people i have a 89 ford courier ute and a vn v6 laying around and im
thinking a might chuck the v6 in it for a skid car,does anyone have any info
on this conversion it does not have to be legal or anything its purely for
fun any info would be great i have done conversions before but just thinking
if this is an easy conversion or not i hope so,should go pretty hard i think . . .
Pub247
Melbourne S.E.
Ford Fairmont
dunno about courier but i saw a hilux tray back with an l67 in it so it should be possible. I suppose custom engine mount is going to be the main issue good luck will make a mean burnout car
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
yeah engine mounts and g/box mounts wont be a prob im a boilermaker welder by trade dunno if i will have to make a sump etc is it hard to wire in the ecu i wont be trying to wire it in to the old harness i will just use switches
Pub247
Melbourne S.E.
Ford Fairmont
boilermaker like me then huh well your set then. Yeah sump might be an issue depends only where crossmember is how far forward or back you have to mount it.
Wiring i dont think is too hard theres the engien loom with only really two plugs to wire up most are power and ignition with a few diagrams, a few hours and half a brain you should be able to get it running
greenfoam
101
VP Executive R-spec
There's a couple V6 powered van's around here. You get quite the shock seeing some old van rock up at the drags and mixing it with the V6 boys :) and enter the burnout comps
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
hey foamy yeah i reackon it will be a blast do you reackon i would be better off doing this courier or taking all the weight out of a vn/vp putting some wild gears in it i think i have got some 4.11 in the shed and a tune ????? i dunno
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
anyone else got info
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
is a vn motor the same as a vr like i mean if i put a vn motor in a vr will it run
maginoodle
vy series2 ss crewman
pretty much the same, i dont know everything that got changed but the wireing is basically the same. also things like the thermostat etc were moved.
