well i own two vs's a sedan and a ute i used to have a vt sII it ran great but it didnt have enough power beeing a heavier car and just a v6 auto they need at least a 5L/5.7L id say. the vr/vs has been the fastest newwer v6 commy ive driven (i havent driven any older than vn) my step dad owned a vr and my first car was a 5spd vn berlina the vy i found very dissapointing as far as power and comfort
the vs has plenty of go and a cai and k&n filter makes em have just that little bit more.
i picked my 96 vs sII sedan up last september for $5500 with 159000 kms immac interior dodgy exterior eg dents scratches etc has been running fairly well since purchase just has very high fuel consumption which we have nearly sorted that out i just bought my 95 vs ute a week ago i paid $8000 for that its pristine with 109000 kms just a slight teething problem with the oil but i knew i was getting into that before i bought the car.
problems ive had
vs sedan high fuel consumption 220kms to a tank/black smoke (running rich) / rough start, rocker cover gaskets leaking (minor), grinding idler bearing
vs ute, rocker cover gasket leak (major), oil thickener mis-use from previous owner trying to stop rocker covers from leaking/ dirty cooling system / thermostat replace (for good luck
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
), sqeaky idler bearing
vs sedan replaced
idler bearing
rooflining
a/c switch
dash fascia (broke the vents off trying to replace the a/c switch)
oxygen sensors x2
fuel pressure regulator
spark plugs
spark leads
fuel filter
ECU (computer)
vs ute replaced
exhaust (stocky keep it nice and quiet for my music old one rusted out)
few bottles of oil and a couple oil filters
some coolant
a/c switch
instrument cluster (from level 1 to level 2, also sticking)
saggy rooflining (yet to be replaced)
broken sun visor clip (replace on the weekend)
idler bearing (replace on the weekend)
so ah yeah sorry for the whole life story im at work so i should be working !!!!!! hope this helps a little
