Buying a VT SS 5.7
minux
2017 SSV Redline
Start the car up dead cold, you will soon know lol.
If it hasnt occured after 100,000k i doubt it is going to happen :)
EXCESSV
39
Perth, WA
VE SSV
my clubby is only 41,000km old, no engine change (number match) and no piston slapping...as fas as i can tell
Trewman
VF SSV
is piston slap where because they are cold they havent expanded yet so there is a bit of play?
My cousin rebuilt my vt 5.0 motor bottom end up and it slaps when its cold now.
holden007
VRII
Subaru Liberty
Your one of the lucky ones!!!
Chilli_Red
Brisbane, QLD
2000 VX XU6
rear camber wear is an issue with the vt aswell. I'm not 100% sure how too explain it so ill leave it to someone who knows more about the problem.
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
The insides of the tyres wear prematurely.. Sometimes they can wear the tyre out after 8000km.. It can f*ck up the inner sidewall, meaning you HAVE TO replace it or you'll be all over the place..
So pretending you're looking at the right tyre from behind..
Instead of looking like |_| it'll look more like \_|
The problem was rectified in the Series 2 VX with an adustable control arm, but the VT and VX1 can be fixed with a camber kit, just talk to Pedders and ask em about a 4 point kit.. Probably about $500, but it will save your tyres..
And good to see a Ford driver here offering help.. Good stuff mate..
patullose
Sean
Sunshine Coast QLD
Vr Exc 1994
Wow was it really that bad of a problem? Does it do any damage to the engine?
minux
2017 SSV Redline
Nope, i know guys who cold start slap all the time. What peopel do not realise is that due to being an alloy block eveyr sound is intensified 100x, so it sounds worse than it actually is :)
patullose
Sean
Sunshine Coast QLD
Vr Exc 1994
Ok cool thanks for your help mate
minux
2017 SSV Redline
One thing, try and surprise the owners so they can't warm it for even 30 seconds prior, hard to do, but you want it bone cold.
