Bypass Air-Con.. Good idea??
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Bungle, Oct 21, 2008.
  1. Bungle
    Bungle Bungle
    VP Exec S2, VZ Exec
    Whats the cons to removing the aircon in my VP? Is it as easy as whacking in a smaller belt? and if so which belt to use?
    If anyone has tried this, let me know how things are going..
    Cheers..
  2. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    Yeah easy as a new belt just ask for one without aircon. Benefits arent much unless you remove the whole system and youll save about 25kgs of weight
  3. sv5g
    sv5g New Member
    Sheidow Park, S.A.
    VN SV5000 & VN V6 Calais
    The only con is that you won't have any cool air coming in through the vents!! Won't hurt anything, I did it on the VP I used to have as a temporary fix until I could afford to fix the A/C compressor bearing.:thumbsup:
  4. mattakaspeeedy
    mattakaspeeedy New Member
    VR V8 BT1
    Also any suggestions on what i could use to space out the p/s ?
  5. greenfoam
    greenfoam New Member
    VP Executive R-spec
    The Aircon cuts out at full throttle anyway so there's no gain at full throttle with just the small belt it doesn't take much/any power to spin it when it's not engaged. But if you remove the whole lot the weight gain is worthwhile
  6. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    hehe i think you mean weight loss foamy.
  7. h0Ld3n`VN
    h0Ld3n`VN New Member
    NO CAR ATM.. -.-
    why dont u make a switch for the compressor to spin like a rocket? so ur car turns into one.. lol jokez :p, i removed mine n it still blows out cold air? is that normal..
  8. levymetal
    levymetal TURN MY HEADPHONES UP
    Somerville, Victoria
    HSV ENHANCED VP CALAIS
    should be whatever temp it is outside on coldest setting
  9. savage1987
    savage1987 Donating Member
    unless the little white plastic lever isn't hitting the shutoff switch on full cold... like mine... then you're left with a metal pipe right near your left foot that's constantly at 98deg or so.. :(
