calais dash
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by shonky12, Oct 14, 2011.
  1. shonky12
    shonky12 Member
    hi
    when installing a calais dash into a 96 vs executive
    1. what wires on the 4th plug do you need to hook up if you just want the bit that shows how far the caras been and light up when the rest of the dash lights up at night when the tail lights are on.
    2. how much modification needs to be done to the wiring in a vs exec to fit a l3 dash
    3. is the plug already hidden in a 96 vs exec
  2. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    The 'Tripin" thread is a great read on this.
    Just add the L3 plugs to the Exec loom
    No - the 4th plug wont be hidden.
  3. shonky12
    shonky12 Member
    what wires do you add id you only want the digital speedo counter
    will a vr calais cluster work in a vs
    how would you add the plug that goes where the speed alert used to be and connect the wires already there
  4. 88GreenVN
    Surprise, Arizona
    Orange white and black white wires as per the wire diagram will show the ODO.
    VR will work OK in VS - but your seat belt warning will be an air bag worning
    The speed alert is differnt wires and cant be used for the trip switch block add the to the loom by running extra long wires to the 4th plug and main dash loom by the drivers side (if your not removing the loom)
  5. shonky12
    shonky12 Member
    so with the speed alert do you cut the plug off and join the wires to the leftover wires on the plug for the trip computer switch block in the vvr/vs
