Calling all VE owners. Help required.
Tones
Donating Member
47
SA
VX SS SERIES2
Hi everyone,
I normally hang out in the VX section, but...
My mates lad has a SV6 VE manual Ute and I helped him install an amp and sub yesterday. We tested and was all working fine, but once we had it all back together, the strangest thing seems to be happening.
Ignition on and the cabin fan is constantly running, but controls are unresponsive.
Can’t turn fan off, up or down. Can’t turn A/C on or off, or even change which vents are on.
Initially it came up with “security link mis-matched” and no stereo.
Pulled it apart again, checked everything and all appeared fine until we adjusted the steering column.
Ignition off, then back on and it was fine again.
But as soon as you touch the steering wheel, the fan turns on again and remains unresponsive.
Power for the amp is straight to battery via the fuse, negative to chassis, speaker signal from front speaker wires and remote I tapped into the acc wire behind the white plug under the dash.
Has anyone ever experienced anything like the above mentioned?
It really has me baffled.
I’m hoping there is someone out there in this mighty Commodore community that could offer some advice.
Mich appreciated and thanks in adavance.
Tonesss.
lmoengnr
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Try disconnecting the battery for 30 minutes.
Tones
Donating Member
47
SA
VX SS SERIES2
Thanks mate, I’ll get him to try that.
I appreciate the time and help.
Tonesss.
Jack D
55
Aberdeen
2012 VE Thunder
Hi Tonesss,
Would you have instructions to install amp sub in sons VE ute?
Thanks.
