[Ecotec] Cam Crank Voltage
Draimond
VS V6 Executive
What Voltage should the Cam and Crank sensors be supplied?
Haltech have 12V up on their Buick/Ecotec info page.
Posts on here reference testing these sensors and seeing 5V.
Draimond
VS V6 Executive
I'm going to assume it gets supplied 5V.
It wouldn't get a 12V power supply and then output a 5V signal to the PCM....... would it? Hahaha
Draimond
VS V6 Executive
Just spoke to Haltech and the bloke I spoke to said that's exactly how the sensors work, they take a 12V input and output a 0-5V signal for the ECU.
Power from the fuse box in the engine bay can be unshielded, signal and signal ground wires should be shielded.
I still don't understand why a signal ground wire needs to be shielded when its shield gets spliced into the signal grounds at the ECU anyway.
I need aspirin...
Draimond
VS V6 Executive
Would anybody be able to test the cam or crank sensor for me on their car?
Should be ground, power and 0 to 5 volt on the cam. Ground, power plus two sets of 0 to 5 volt on the crank.
I would assume you can test the by turning the ignition on and unplugging one of the sensors, then probing the connectors pins with a voltmeter.
The cam and crank sensors voltage input is shared, the same wire is spliced into a single output on the DFI module. So test whichever is easiest to get to for you.
Basically I just need to know if you're getting ground, 12 volt and 5 volt or ground and a bunch of 5 volt.
I think the only thing I can do at home would be to throw the DFI module on the bench with a battery and see if I can get it powered up out of the car as I've already chopped up my wiring harness and fuse box.
07GTS
Australia
VEGTS BUILT BLOWN E85
top diagram here may help its VS - VY
07GTS
Australia
yea sounds like the battery 12-14v supply for it, is the reference wire 5v when sensor disconnected ? most of the time that can be a 5v from ecu and the sensor just needs power/earth and then it just pulls that 5v down to zero when it passes teeth
Immortality
Staff member
Sth Auck, NZ
I think it's 12 volt in as the supply but the signal is 0-5volt out.
Draimond
VS V6 Executive
I don't think it's 5v disconnected. I believe the sensors has a resistor that pulls the 12 volt down to 5....
I'm going to run with Haltech's advice that it takes 12 volt in. It's going to be a massive job if it's wrong, because my 12 volt is in the engine bay and my 5 volt supply is from the ECU and they need to be shielded wires.
Immortality
Staff member
Sth Auck, NZ
The CAS is a hall effect sensor x2
