Cam into NA 3.8, parts needed?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pow3rslave, Feb 18, 2007.
  1. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    for a while i've been thinking about putting a mild cam (no headwork) into my V6, i heard some figures round here for work done professionally at something like $2K, so i got a quote from a chick i know's missus. he reckons $1200 mates rates including parts, but not the cam,
    he said he'd be getting the parts at cost and that i'll need a new timing cover and gaskets for the head and rocker covers.
    with that in mind is this a bit of a steep quote for this, he basically works for beer so how much do these parts go for?
  2. defa
    defa New Member
    VN Commodore
    why would you need a new timing cover. yeah that i way too steep i reckon. that isn't much difference to the $2000 quote by the time ya buy the cam.
  3. Morton
    Morton For external use only
    Fairstar the Funship
    I would have imagined something more like $600 for parts and labour, but there you go. Gaskets aren't exactly made of gold... they're not expensive.
    edit: if you're not doing any head work, and you only want a mild cam, have an ask around and see if you can get higher ratio roller rockers that give you a similar effect. If you can, then do, because they'll be cheaper - and you can install them yourself.
  4. pow3rslave
    eastern subs, vic
    VP 5.0L
    yeah he reckons those parts and bolts/studs (which i don't know much about) but i already have a set of rocker gaskets, so that's taken care of.
    anyone know what a timing cover will cost?
    i was gonna go the roller rockers option before i even considered a cam, but doesn't a cam have benefits over them?
  5. defa
    defa New Member
    VN Commodore
    why do you need a new timing cover. is your buggered???
  6. pow3rslave
    eastern subs, vic
    VP 5.0L
    that's just it, its going fine as is, so i don't know why i'd need a new one, unless the cam will put it out or something.
  7. hakhawk
    cam shoudl fit fine inside old one. easy way si to ask him why you need a new cover and see what he says.
  8. Da Flyin Dutchy
    Da Flyin Dutchy New Member
    Cessnock NSW
    Triton VN 3.8lt
    in my estimate a full rebuild set (gaskets rings bearings seals)basically the works would cosl around 4 to 600 bucks. The only reason that you could need a TMG cover is if yours is corroded from inside out. This guy wants to rob you blind. Since you live in a van you would find it cheaper to drive to Greenhills in NSW and do your bussiness through Doctor Macs. They are reliable and well priced. Or come to my place in cessnock NSW cause i reacon i could see your car finished for about a grand and you would get more than just a cam.
  9. defa
    defa New Member
    VN Commodore
    ya gotta hae a special tool to put cam bearings in don't ya.
  10. cracker
    cracker New Member
    probley wont have to do the cam bearings cams are about $600, the timing chain $100, then gaskets $50, manifold timing cover front seal etc
    then all that labour.
    600 for parts and labour ur kidding, ud be looking at about 1000 all up i reconif not more, if ur in melbourne ill do ya cam for $200
  11. Morton
    Nah mate, this man quoted him $1200 for the job with the cam supplied. i.e. that's $1200, and then $600 on top of that for the cam.
  12. pow3rslave
    eastern subs, vic
    VP 5.0L
    yeah i'm thinking i'll ask him for a full breakdown and buy parts myself and bring em to him.
    alternatively i'll just go the roller rockers
  13. ephect
    ephect Donating Member
    VS Acclaim V6
    the only real advantage of a cam over roller rockers, is u duration and overlap. they both provide lift.. u could get a lumpy cam that opens the valves a smig longer, as well as big lift..
    see i would have said rockers would be the cheapest.. but ur looking around the $600-900 mark for rockers dependin on how much lift.. new rocker bolts $30, and install should be $0 coz they're easy as, now that takes u to about the same mark as installing a cam, if u spent a lil more $$$ on the cam n get something lumpy n with big lift, ur gonna be in front in the end, u can always port the heads later down the track..
    if u can get mates rates on the cam.. ur laughin!
