cam upgrade
sir355
Father Figure
Cairns
VR SENATOR 215, HZ ute
mate depends where you live. I just got quoted 1500 to put in a 288 solid, so you should be looking at around 800 - 1000. Good cam the 286, i've got one!!
dmitch
DonkeySS
37
Perth W.A
VS SS S2
just got quoted 1000 for cam and lifters.. am currently running a 276.. wat sort of power increase would i get from putting the 286 in.. thanks
sir355
Father Figure
Cairns
not sure on increase, the 286 requires that you have a fair few mods to your car, wat have you had done to it?
dmitch
DonkeySS
37
Perth W.A
VS SS S2
quite abit of work.. bottom end worked.. heads worked just need 2 b port and polished... just need high stall and diff ratio changed... wat stall u got 4 ur 286..
sir355
Father Figure
Cairns
mate i'm running the six speed, so as much stall as i want. lol..
With mild head work, hypertech pistons, rollers good coil, roller rockers and good exhaust my 215 put out over 320hp at the wheels with the 286 and that was with the standard intake
dmitch
DonkeySS
37
Perth W.A
VS SS S2
k... im looking into getting a torgue-power manifold still researching. and researching prices on a stroker kit.. for abit more power
sir355
Father Figure
Cairns
i've gone the harrop, 1000cfm setup route.
sir355
Father Figure
Cairns
yeah will do mate, i have to get a programme to shrink it as it is to big to attach.
