426Cuda
SUBLIME!
- Dec 15, 2013
- 4,181
- 3,015
- 113
- Location
- Wagga Wagga
- VF Redline Sedan - A6 Spitfire MSE...
But then you don't get the benefit of the big mouth pickup, and the risk of windage is still there too. Extra capacity in the sump helps to avoid this. Extra ATF in the cooler and tubing doesn't. From what I've read, the cooler typically only adds about 500-750ml.Why not adding instead a Transmission Oil Cooler? Increase the capacity, better heat transfer and keep the OEM low profile.
BTW, the Camaro pan is a stock GM part. The profile is plenty low. It doesn't hang down, I.e it's still well above the exhaust etc.
