King_berald
- Oct 16, 2007
- 403
- 9
- 18
- VX Berlina Wagon
thanksguys....what about the toe link? im asuming thats the little bar from the control arm to the car?...how is that problem rectified?
you can only use the 4 point adjustment on pre-vs irs
If you constantly tow with this car, I'd suggest getting some airbags fitted to the rear....This helps keep the rear end adjustments correct....by adding weight to the rear, the rear "squats" down, which effects camber and toe....Adding air to the bags, lifts the rear up, to where it normally sits, therefore preventing premature inner edge wear....
The cost is about $400 to $500 installed, but cheap compared to replacing tyres constantly
Sorry for been a total newb / noob but we all had to start somewhere. My Right rear tyre is wearing out majorly on the inside only. I was told once before that I need a towing kit, and to go buy one, get it fitted and then return to get the wheel corrected. Yet, everytime I search for it, or ask around I get pointed to tow bars and stuff. I couldn't see how this is going to fix the problem. After reading through the forums I found this page. maybe they meant to say toeing kit. From what I've been told I have the early model VX 2001 sedan which doesn't have any rear wheel adjustments (so I was told). I could check the vin plate if it helps. or look for something if someone provides a photo of what I am looking for. Do I purchase something like this??
Super PRO IRS Rear Camber Adjustment Bush KIT FOR Commodore VT VU VX VY VZ | eBay
or is it something different?
Any help or links, suggestions, etc. I am a country pensioner so I can't afford much and after talking with the local suspension place they are asking for $80 just to take a look. :-(
Thanks In Advance -Fred
JUST GO READ VY INTO VT ,YOU ARE BETTER OFF GETTING A VY REAR END AND PUT IT IN ......:boxing:
