Cammed LS2 - What engine oil?
Discussion in 'LSx Development and Modification' started by Jesterarts, Jun 8, 2011.
  1. Jesterarts
    2010 Nissan X-Trail ST-L
    Hey guys,
    I have a LS2 that has been cammed, had heads, springs and double row timing chains down.
    My question, what is the best engine oil to use?
    I know HSV recomment Mobil 1, but is there anything better? And what weight should I use?
    Cheers.
  2. Grennan
    Glen Waverley, Victoria
    VE SSV G8 Sportswagon
    How many K's?
    The guys on the LS1 forums swear by Castrol Edge 10-60. Its ####ing expensive (anywhere from 70-90 dollars a bottle and you need 2 bottles) and I found my engine didnt quite like it, was a tad noisy.
    Another high recommendation from the LS1 forums is Penrite HPR 10 (10-50 I believe)(and HPR15 which is 15-60 for summer/higher k's) both of which are easy on the wallet. Ill be trying HPR10 in about 1000km's time.
    Generally you're looking for around a 10w. Holden recommends 5-30 Mobil, but remember thats for a brand new car, I wouldn't use 5 weight.
  3. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    Not the same but my ve will be cammed next month ect, i have about 38,000kms and i use royal purple 5w30, totally quite on cold and warm starts runs very well, wouldnt use anything else
  4. hsv453
    hsv453 New Member
    Mildura
    HSV Z series Clubsport
    ^^ i run royal purple 10w-40 in my unopened ls2 and my tuner says when the cam is in to continue running royal purple 10w-40 or lighter 5w-30. Top stuff :)
  5. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Yep once i get to 90,000 or so ill switch to the 10w40 but you really cant go wrong eitherway with the royal purple
  6. Bravotwozero
    Bravotwozero New Member
    MY12 AMG C63 W204 Speedshift + 2013 KW T909
    Holden recommend 10-30 for efficiency reasons. 10-60 will offer more protection although I've always used 10-40 in mine.
    (LS1 & LS3)
  7. cpbait
    cpbait New Member
    vy ss commodore 5.7ltr
    iv used 10-60 edge was good, been using magnatec 10-40 and that's been fine, Royal Purple seems to be popular in the states.
    put 5-50 mobil 1 full synthetic in my ss and the engine is noisier hot and cold.
  8. Lumps of cheese
    Lumps of cheese welcome to the machine
    Warrnambool
    83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
    Always ran 5-30 mobil 1. Never had any complaints.
  9. RIDE:42
    RIDE:42 crew chief
    vuss
    i use to use hpr 10 then went over to castrol 25 50 and never looked back also use it in the Twin turbo set up i have in the ute now [​IMG]
  10. Jesterarts
    120,000km. About 3000km with the mods and I drive it around 200km a week.
    Yeah, with the cam and gears... efficiency in not a concept my car understands.... :p
    Thanks for the responses guys.
    Looking like the Edge 10w60 is the winner. So far mostly all positive comments about it.
    I'll have to inform my mechanic... :)
  11. Grennan
    Just hope they have 10-60 in drums. Because you need 1 and a tiny bit bottles of it and you cant buy 1 litre bottles so you need to fork out for 10 litres.
    ...I liked what Chevs used in mine when they serviced it and did the tune. Oleon, not sure on the weight, but was nice and quiet.
  12. dirt drifter
    dirt drifter white trash hillbillie
    massive hole in the ground
    VS 5L M6 VS 6L M6
    +1 for edge 10-60. i went with it based on the research i did, as grennan said the ls1 forum guys love it.
    its a bit noisy but it was the same with the oil in it when i bought it, dunno what breed that was.
    grennan, i recall on the aussie ls1 forum some guy was looking into a bulk buy of edge 10-60. dunno if it was 20L or a 44 gallon drum but he reckoned he knew the local castrol rep but even so it wasnt much cheaper in bulk at all, dammit
  13. Grennan
    It was a 209 litre drum and it was just over 3 grand. It wasnt cheaper to buy it in bulk. However, thats direct to public prices if I recall correctly, if you got an existing customer to buy it, Im sure youd get it much cheaper.
    Im gonna try HPR10 next oil change. If not...back to the Castrol.
  14. cpbait
    cpbait New Member
    Apparently there's not much margain in engine oils, we used castrol edge 10-60 in the 200 liter drums at a dealership i worked at for some of the european cars before they switched to the manufacturing selenia oil as it become more readily available i guess, the selenia oil was awesome, i used there selenia 5-40 i think it was, it was a racing blend for the performance type engines and engine, felt like it went better like less friction.
  15. marq75
    marq75 New Member
    Bradenton Florida
    2006 Pontiac GTO
    I like to use Royal Purple 5W30 in my cammed LS2.
  16. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    sweet car man , in the best holden color ever too imo.
    You son of a bitch. :beer chug:
    edge 10-60 is what i use in my LS1 with no complaints
  17. SirNemesis
    SirNemesis New Member
    Geelong, VIC
    WHII Statesman
  18. Darcon666
    Darcon666 Evil is always around you
    At home
    The Wife
    :yeah: Edge 10W60 here as well.
  19. Jesterarts
    Got me some Castrol Edge 10W60 today. :)
    Thanks guys.
  20. Grennan
    You'll start to stock up when Supercheap does sales. At my work we sell bottles of that **** for 90 bucks retail and I dont think Repco is much better whereas I think Supercheap sell it for just under 80. You can get then for like 60 bucks when they do sales. But you gotta get in real quick because they either a) sell out real quick or b) take it all off the shelf.
