Can a bad cluster stop cruise control
imrhoss
1996 VS Statesman, 2013 VE II SV6 Thunder Ute.
Hey fellas, recently taken out my cluster a couple of times in the last 24 hours, stupid globes went out a couple of times (different globes) the globes are now working, but my cruise control isn't :( I've checked the brake switches and they seem to be intact. Globes in the tail lights are fully working. The cluster is the only thing that was played with. Basically I can turn it on and get the green CRS light to come on, then when I go to set the speed, the orange 'ON' light flashes for a second then it won't set. If I press the brakes and try to set it, nothing happens, no orange lights, which indicates the brake switch is working as it should. Any ideas? I've had a peak at the circuit on the cluster, no traces seem to be cut or anything.
Sent from my GT-I9505 using Tapatalk 2
ephect
Donating Member
VS Acclaim V6
Mime did that when I replaced all globes with LEDs.. Had to leave one globe for it to work. Don't know if uve done a led conversion recently?
Unless a track is broken on the cluster?
imrhoss
Good pickup! I've replaced the bottom section (3 windows, lvl3 cluster) with leds, will rip em out tomorrow and re test. Cheers :)
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Make sure the cluster is bedded into the dash plugs nice n firm. If you have replaced the trip computer - that connector can be faulty.
imrhoss
I may have accidentally damaged it. It's a bit worn out
88GreenVN
Next Exit Left
60
Surprise, Arizona
If so, you can just change the green backing to the cluster (No. 41772) from a spare.
imrhoss
Cheers man, you're a legend. All working now. I guess after all the cluster can affect the cruise control! So happy to have it back.
