can a vn speedo go into a VP cluster
reddevil6
VB Wagon
Hey guys my speedo in my VP cluster stoped working on have a vn cluster that only the speedo works can I put the speedo from the vn cluster into the VP cluster or will it not work ign and the VP speedo does work but the needel droped bout 5vn or more so it's about 30 -40ks out that's why I want to swap.them
reddevil6
VB Wagon
Ign **** sorry about the spelling same auto spell on my phone
hi_ryder
Donating Member
Pascoe Vale South, MEL
my vp cluster has a vs speedo in it. youll just have to change the face plate over if its different which requires removing and refitting the needle. also you should make sure its not dry solder on the voltage regulator board. it starves the gauges of power making them work erratically or not at all. also your speedo gear in the trans could be kaput...
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
The Vn speedo head will plug right in. But the speedo needle on the VN can be a real pain to get off and back on - and still get a good reading on the speedo. I'd leave the VN speedo dial alone as in just fit it to the VP cluster and see if you can get the VP unit fixed up.
