Can a VT Berlina have steering wheel controls installed?
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
you will need to make up the wiring loom, i spose i can part with one for $25
Rob
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Rob
Without that loom module wouldnt work,so can u make one up?Cause i got no idea.
holdenrules
VIC
Hi all,
Does anyone have a wiring diagram or knows which two wires are used for the steering wheel controls for a Series 1 VT Berlina?
My head unit is the stock Eurovox with a single CD, the part number on the sticker on top says 92050102 and has a single connector on the back.
I read somewhere it was pins 9 and 16, and different resistance across them do different functions. I connected the controls to both pins with hook up wire to test it and it didn't do squat.
As I was testing it, I didn't run it through the clock spring, would that have caused it not to work?
Apparently no resistance is Volume Down, so I tried shorting the pins directly and that did nothing as well, the volume stayed at the same level.
Thanks,
