Can i change a head gasket in a day?
peanut_finger
VT EXECUTIVE
Okay here it goes. I have had a intermitent overheating problem in my VT V6. I have draned and flushed radiators and stuffed around with numerous other things but it will still over heat at inconsisent times. A friend of mine says he had the same problem and it was a head gasket. She has been using a bit more water than usual and has developed a bit of a hesitent miss at times.
Can anyone suggest if I can change the head gasket with minimal mechanical experience. What sort fo time frame am i looing at to do this?
I have one of those gregorys manuals that explains it, but i dont want to get myself in a mess over the weekend without any transport.
VN_Luke
ƃuoɹʍ ʇsnɾ sı sıɥʇ
Mexico
Get in the ute
The reality is - things can and will go wrong.
If you've never done such an operation, it's best to give yourself a few days 'error buffer' after you start the operation.
you'll need more specialized tools like a torque wrench, for example.
if you follow the gregory's book closely, there's no reason you shouldn't be able to do it - but allow for stuff ups, breakages, etc. (so don't expect to have it ready by monday :p) - specially cause you can't buy parts on a sunday afternoon!
anyway - before you rip the heads off - go visit a mechanic and see if they can diagnose it for sure - it could be something as simple as a heater tap leaking - and the miss could be unrelated.
does your oil look like custard?
do you get steam out the exhaust when car is warm?
vt s
vt s s1
When you say minimal mechanical experience how much exactly?..
Agree with luke, dont start ripping the head off until you know for sure its ahead gasket. Have you checked your oil? If its head gasket the oil will be a milky colour, also try this.. when the engine is cold take the radiator cap off and start the car and post your results.. Or just take it to a mechanic and see if they can check it out for you.
-Michael-
Ooh Yeah.
VT S Pack
Check your heater tap first ;)
minitsbay
vt executive
i have same problem mine isnt heads its intake maniold gasket
azkwazere
Ahhh Yes, Ahhh Yes....
33
.....SE Burbs
VP 5-SPD / 24-SPD Racer Hybrid
i was about to add this, its usally this first... commonly confused
aZk.
vxcalais_01
VX Calais 3.8
Took me a day for intake manifold. Remember oil changes and coolant changes take a bit as well.
You cannot do it properly in just a day. What if you need to deck the heads etc ? Gotta clean up the block properly etc.
Paiste402
My workin on the car face
Normanville SA
1992 EB Fairmont Ghia
when i did my head gaskets on my old VC i thought it would take too long, then i found that the cylinders need cleaning, then i learnt how much scraping is needed to get all the old gaskets off (ALL OF IT), found out my lifters were shagged and needed new ones, found a bent push rod and had to clean the others ect ect ect ect.
Dont rush it, get the gregories book and take ur time, have all ur tools ready and have a big clean table to sit all the rockers and pushrods in so they stay in the correct order. You will know so much more about ur motor afterwards lol!
Best of luck mate
mitmit
vt
i am having same problem too,
my car just broke down and my radiator was empty
so i refilled it again rying to drive the car home untill the engine is having knock sound now
then today i start pull things apart
open the inlet manifold and found the coolant inside mixed with oil
so pls guys i need help too
is my car problem worse about the knocking sound? need help pls
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
mitmit ; You shouldnt pull anything out b4 testing few items ;
Water pump efficiency, thermostat operation ,radiator leakage ,cooling sys. pressure test and finally compression test.
The water u've just seen (after taking the inlet man out) came from the manifold ,cause u've tilt it whiletaking it out ,oh if its green wouldnt worry about it too much,but if its caramel brown ,yeah go and replace whatever.you fancy.
Knocking noise is very common for these engines.There is no quick fix.put up or spend $$$.
