can i change the rear things myself?
Hairy Eater
Banned
Queensland
2000 VX Executive V6
you dont need a spring clamp .... unbolt the shockies and the springs will fall out ... if you are to super lows you'll need shorter shocks than normal shocks if you dont already have them .... if not the springs will fall out if the car gets airborne over speed bumps ....
VL-187
ZZZZZZZZTUUUTUUUTUUU
34
Bagged VS calais II
yep, i got superlows in the rear with my normal shocks, no problems at all....
think ull find that u will get mixed answers to this question.
beeks
Banned
N.S.W
XR6 5sp MKII + DR 600S
Or roundabouts.
mjm4676
44
Lennox Head NSW
VE SS Ute, 94 Swift Cino
I did mine myself (Holden mechanic) and the easiest way i found was to undo shock and driveshaft (not undoing the shaft wont allow enough travel for control arm to drop) and then pull the spring straight out. Put jack under control arm so you can do shock up and refit shafts, and bobs your uncle.
Hope that helps.
Mick
